Question about Belling FarmHouse 931 Gas Kitchen Range
Belling farmhouse 911
I have been offered the above appliance but would need it to work on bottled gas, what conversion would be needed?
  • 868 Answers
Propane I take it.?Order from a parts house the "propane conversion kit".It should have orifices (2-3) and a spring .You Have to replace the parts to allow the propane to work. Please Rate This !!
Posted on Jun 07, 2008
Looking for door hinge 082600712
Lisa, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Oven Parts Appliance Parts from PartSelect
Oven Door Hinge Parts Accessories eBay
Oven Parts Appliance Parts from Easy Appliance Parts
Mar 07, 2016 | Belling FarmHouse 932 Dual Fuel (Electric...
Belling Farmhouse 911
if you check it and see it that it will not work fine even try repairing it, much better to replace it.. & also please the burner for some dirt that makes the gas not flowing normally..
Thank you, & post back again for any further assistance..
May 08, 2008 | Belling FarmHouse 932 Dual Fuel (Electric...
Common faults with Belling FarmHouse 932
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling FarmHouse 932 Dual Fuel (Electric...
Belling Farmhouse Cookcenter Model 111 main oven wont reach temp
Same problem here too. Plus the in-game assisted oven has a similar problem inasmuch as the flame goes straight to max and won't reduce. Please help
Apr 05, 2010 | Belling FarmHouse 931 Gas Kitchen Range
The ignigter in the oven keeps clicking all the time the oven is on ? the model is 911
The clicking is not in the oven. You have a bad surface burner switch. Open the front control panel to access the surface switch. Remove one wire at a time for each surface igniter. They are located on each burner valve stem. When the clicking stops, that will be the bad switch. Replace it.
Jun 12, 2009 | Belling FarmHouse 931 Gas Kitchen Range
Belling FarmHouse 931 Gas Kitchen Range Logo
330 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
