Question about Sony Playstation 3 (PS3) Console
Ps3 there is no red cables conected
  • RescueTechLA
    RescueTechLA May 11, 2010
    What's the question?
  • J4XXN
    J4XXN May 11, 2010
    what?!?!?!?!?
    Problem Solver:
  • 18 Answers
I assume you have nowhere to connect the red cable.
This is ok. The A/V outlets on your TV only has 2 ports. It's ok to plug the yellow and the white and leave the red.
Posted on Jun 03, 2009
I dont have extra hdmi connections so i use av multi with the red/blue/green(no red/white on cable) conections with an optical cable- which will not play sound. What am i missing?
I honestly thought it would have the white red and yellow as well. If it does try plugging in the yellow along with the ones you already have. If not then try plugging the green into the yellow hole.
Apr 12, 2014 | Sony Playstation 3 (PS3) Console
I changed the PS3 setting to view on TV from HDMI to Ycp? (red blue green cables) now I can't see the PS3 menues, how do I change it back? can you help please My PS3 has no Red blue and green out
try taking out the red blue green cables completly out so no cables should be conected exept for the power cable then plug in the hdmi cable from the ps3 to the tv after you do that turn on the tv to hdmi input then turn on the ps3 and let it sit for a while and look at the tv while the ps3 is turned on shortly after you turned the ps3 on a message should pop up on the tv select yes then set the settings and that should work let me know if it dosent
Dec 08, 2012 | Sony PlayStation 3 (320 GB) Console
Hi i have a samsung sp50l 7hx and just bought a ps3 tried to conect with hdmi leads and also red white and yellow leads just getting a blue screen up and not sure what to do as i havent got tv manual
I believe that the PS3 only supports one output at a time you could try unplugging the a/v cables and leave the hdmi cable inserted you should get picture and when you do change the settings of the PS3 to support 720p or 1080p as the quality will greatly increase.
Apr 25, 2010 | Sony Playstation 3 (PS3) Console
Sound problems
USE THE OPTICAL CABLE ,,MAKE SURE YOU CHECK THE BOXES ON THE SETUP AUDIO PS3,, LIKE DTS,,DOLBY,,LIKE THAT
May 13, 2009 | Sony Playstation 3 (PS3) Console
Ps3 doesnt recognise both controllers
conect the usb cord to ps3 and hit ps button on each controler to link them to system after conecting the usb cables to controler
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Cant connect via hdmi
Put it in standby (Red light) and with the HDMI cable conected, press and keep pressed the on/off button in the console for about 5 seconds.
I hope that helps..
Let me know if that solve it..
Computerrep
Dec 23, 2008 | Sony Playstation 3 (PS3) Console
Ps3 usb modenm
you dont use a wirless stick on the ps3
the ps3 has wirless built into it
to conect to the internet you ethier need to conect it to a router though an ethernet cable
5d768cd.jpgor using wirless to conect to a router
PLZ RATE! :)
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Hdmi connection doesnt work on ps3
By you saying that you have a new cable & tv, I assume you had the console conected tru composite before (red, white & yellow rca cable). This is what you need to do: Connect the PS3 to the tv with HDMI cable only, do not use the composite cable at the same time, reset your PS3 by pressing and holding the power button, when the power is off, for about 7 to 10 secconds, it would cicle from power off, on, then off again, it would also give you 2 sets of beeps, after the power is off, turn your tv on, make sure you select HDMI input on it, then turn your PS3 on, the console would set itself to the best resolution available on your tv. Give it a try!
May 22, 2008 | Sony Playstation 3 (PS3) Console
PS3 conection cables
Suggest using HDMI or Component Video if you can. They provide the best picture quality. Should be able to use RCAs if need to.
Try switching the TV Mode. TV may have multiple modes if you have multiple connections.
Mar 24, 2008 | Sony Playstation 3 (PS3) Console
Ps3 conection
the username and password should both be admin. once in the settings select the ps3 IP and change to a static IP this should just solve your connection problem
Nov 09, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Sony Playstation 3 (PS3) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
