Question about HP Compaq Presario V2000 Notebook
Touchpad goes crazy and right clicker does not work
Yes...mmm I try using the right button but it does not work and the touch`pad somehow clicks everything that passes by
PS: my laptop was not used in like 3 months...does that make any of this sense?
  • H e l p Jun 08, 2008
    K thanx
    Scholar:
  • 119 Answers
Possibly dust might have infiltrated into your touchpad. If you have the necesarry technical experience you could remove the touchpad and clean it and re-install it. another option would be to replace it or otherwise plug-in an external mouse and use that. Thanks.
Posted on Jun 07, 2008
Gateway NV53A 15.6 inch Notebook, touch pad not working
Touchpad settings: right click on the touchpad icon on the Taskbar at the bottom right of the screen. Click on Default button, then Apply, then OK. Re-try. If that doesn't fix, then TouchPad ribbon inside the laptop needs to be replaced.
Feb 09, 2014 | Gateway MT3705 Notebook
The left button at the bottom of my touch pad has a problem. the click is delayed, i have got to hold the click for longer so that the click may occur
@inam_khan_10
Try the following:
1. If your computer is running on Windows, try to boot into Safe Mode (you need to press F8 continuously upon boot-up then choose Safe Mode) and check if your Touchpad left clicker. If it works ok, then a software problem is causing the Touchpad to delay like that. Try reading this guide to solve it.
2. If Step 1 above doesn't work, try to use a compressed can of air to clean the Touchpad clicker and see if same issue occurs.
If still no go, this is a sign that your Touchpad is already wearing out and it needs to be replaced.
Good luck.
Sep 05, 2011 | Computers & Internet
I have a Dell Vostro 1510 and I want to disable the touchpad.
Right click on the open space of the desk top > Personalize > Mouse Pointers (yes, mouse Pointers ) > click the red pointer to change touchpad settings > Button settings > disable both Touchpad and Touchpad buttons > OK
Jul 29, 2011 | Dell Vostro 1015 Laptop
Hello, everything is ok with my mini laptop, but the only problem is, when i use the mouse pad, without me trying to click, the clicker goes crazy and it begins to press on its own.
It sounds like you may have either the wrong driver installed for the touchpad or the sensors in the pad are going bad...
I would try going to the HP site and downloading a new driver...here is a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3832468&taskId=135
Let me know if you need anything else!
Jun 20, 2011 | HP Mini 1000 Netbook
Touch pad working fine but left clicker doesnt
Usually the green means that the button is pressed. Check the touch-pad buttons for dust or dirt. If they're clean, then probably need to be repaired.
Aug 26, 2009 | Computers & Internet
My touchpad right and left click button stopped working
is there a touch pad lock button, that locks the pad? if there isn't then there is most likely excess debris or dust or something under there that needs to be blown out with airisol can. If both of those solutions don't work then i would check to make sure the driver is installed for the touch pad. Good Luck. and i hope it works out.
RATE THIS SOLUTION
Aug 24, 2009 | ASUS Eee PC 900 Notebook
Inspiron 6400 touchpad woes
Hi there.
Try uninstalling the touchpad drivers and utility, that will solve the problem.
Post back if you need anymore help.
Good luck and thanks for using FixYa!!
May 26, 2009 | Dell F3534 Touchpad
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Frozen mouse with a touch pad laptop computer
Many laptops have a button, usually located right above the touchpad, that disables the touchpad.
And there may be drivers that need to be loaded for some touchpads to operate properly, in case you've reinstalled the OS.
Jan 25, 2008 | Toshiba Satellite M35X-S161 Notebook
HP Compaq Presario V2000 Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
