Question about Panasonic NN-S254BF Microwave Oven
Sharp mdl R-1870 convection microwave runs for 1 min
The microwave runs for 1 min and then stops if you press the start button it will run for another min then stop. So if you put 5min on the timer you have to stand there and push the button 5 times. Any thoughts on this
Thanks
  • Anonymous Dec 06, 2008
    identical problem
  • Panasonic Master
  • 9,098 Answers
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Posted on Jun 08, 2008
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
Sharp micro counts down 59 seconds and stops
It seems this has been happening over the last few years. I am a retired appliance tech. My 1870 also started the 59 second routine, Also in a motor home. Pure logic. Had to be the board. New board same results. So now I need to run down a parts manual and possibly service manual, and get the damper switch and motor refered to in earlier posts. Changing out the board was fairly simple. Dropping the unit to change out the other components sounds like it will be a tad bit more difficult.
Oct 14, 2012 | Sharp R-1870 Convection/Microwave Oven
No turntable for sharp R-1870
The turntable motor will need to be replaced, a common issue with most brands.
Apr 21, 2012 | Sharp R-1870 Convection/Microwave Oven
It is a sharp R-1870 turns on and runs but no heat from convection or microwave also carousel does not turn
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 09, 2011 | Sharp R-1870 Convection/Microwave Oven
Sharp R-1870 Convection works, microwave doesnt heat
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Timer shuts off
there was a similar problem posted on your site that solved my problem.
Aug 18, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
59 SEC NEED TO GET FRONT OFF MICRO
If your unit runs for 59 seconds then stops, the problem is the convection damper motor. (Sharp part # RMOTDA222WREZ).
Unfortunately, you cannot access this from the front - the whole unit has to come down as the entire outside cover has to be removed.
This is a pretty major job and the motor (located below and behind the magnetron tube) is rather hard to remove and get back into place. This is probably better left to an experienced technician. You can call Sharp 1-800-BE SHARP for a referral to an authorized servicer.
Jul 22, 2008 | Sharp R-1870 Convection/Microwave Oven
Panasonic NN-S254BF Microwave Oven Logo
206 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
