Question about Microsoft Windows Vista Ultimate Edition
Software issue i just bought a new desktop with windows vista.for internet i'm using to connect with the will phone.but the problem is vista is not supporting that will phone modem software..what shall i do now? i couldn't use the internet without that connection and more over i'm living in a rural area so i cant use the broadband connection too?can u help me to get rid of this problem
    Brigadier General:
  • 10,406 Answers
It's been 18 months since you asked the question.
Check the "Will Telephone" web-site -- by now, they should have updated their software to be compatible with Windows Vista and Windows 7.
Posted on Dec 05, 2009
In windows vista what button is used to create a new folder?
On any version of windows you just right click on the parent folder or desktop and select NEW and then FOLDER. If this doesn't fix your issue, then I need more info to understand your issue better.
Dec 10, 2013 | Computers & Internet
Software problems does not work on windows vista
Check with Navman and ask them if the software will work with Windows Vista.
Apr 30, 2009 | Computers & Internet
Modem
Found this after some deep looking from blackberry itself: Good Luck
A BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
Summary of Tasks To set up a tethered modem, complete the following tasks:
  1. Install BlackBerry Desktop Software 4.1 or later (one time only).
  2. Set up the Internet access point name (APN) (one time only).
  3. Configure dial-up networking (one time only).
  4. Connect to the Internet using dial-up networking.
Task 1
Install BlackBerry Desktop Software 4.1 or later on your computer.
When you install BlackBerry Desktop Software, the drivers that allow the BlackBerry smartphone to communicate through the Universal Serial Bus (USB) port and virtual communications port are installed. The standard modem, which is used by dial-up networking, is also installed.
Note: If upgrading your BlackBerry Desktop Software from version 4.0 to 4.1, the required virtual communications port and standard modem might be removed during the upgrade process. If this is the case, re-install the BlackBerry Desktop Software 4.1 or later and choose the Repair option to re-install these components.
Task 2
Set up an Internet APN.
  1. Click Start > Settings > Control Panel.
  2. Double-click Phone and Modem Options.
  3. In the Phone and Modem Options window, click the Modems tab.
  4. Select Standard Modem and click Properties.
  5. Click Change Settings.
  6. In the Standard Modem Properties window, click the Advanced tab.
  7. In the Extra initialization commands field, type the following: +cgdcont=1,"IP","<your Internet APN>"
    Note: The following is applicable for T-Mobile® customers only:
    The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
    Note: If you do not know your Internet APN, or if you do not have an Internet APN, contact your service provider.
  8. Click OK.
  9. In the Phone and Modem Options window, click OK.
Task 3
To configure dial-up networking, complete the procedure that is appropriate to the operating system you are using:
Windows Vista
  1. Click Start.
  2. Select Connect To.
  3. Click Setup a connection or network.
  4. Click Setup a dialup connection.
  5. In the Dial-up phone number field type *99#.
  6. Type the user name and password provided by your service provider.
  7. In the Connection Name field type BlackBerry.
  8. Click Dialing Rules.
  9. Make sure the profile created in Task 2 has been selected, and then click OK.
  10. Select Connect to establish an internet.
Note: For instructions on connecting a computer to the Internet using a BlackBerry smartphone with CDMA as a tethered modem, see KB04664.
Windows XP operating system
  1. Click Start > Settings > Network Connections.
  2. Double-click New Connection Wizard. The New Connection Wizard opens.
  3. Click Next.
  4. Select the Connect to the Internet option. Click Next.
  5. Select Set up my connection manually. Click Next.
  6. Select Connect using a dial-up modem. Click Next.
  7. If the Select a Device screen appears, select the Modem - Standard Modem check box. Click Next.
  8. In the ISP Name field, type a name for your connection. Click Next.
  9. In the Phone number field, type *99#. Click Next.
  10. Indicate which users will have access to the connection. Click Next.
  11. Type the user name and password provided by your service provider. Click Next.
  12. Click Finish.
  13. In the Connect window, click Properties.
  14. In the Properties window, verify that Modem - Standard Modem appears beneath the Connect using heading, and then click Configure.
  15. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK. In the Properties window, click OK.
Windows 2000 operating system
  2. Double-click Network and Dial-up Connections. Note: The following is applicable for T-Mobile customers only:
    Under the networking tab in the properties window for the dial-up connection, clear the Enable LCP Extensions check box, as well as all check boxes beneath the PPP Settings window.
  3. Double-click Make New Connection. The Network Connection Wizard opens.
  4. Click Next.
  5. Choose Dial-up to private network. Click Next.
  6. In the Phone number field, type *99#. Click Next.
  7. Indicate which users will have access to the connection. Click Next.
  8. Type a name for your connection. Click Finish.
  9. In the Connect window, click Properties.
  10. In the Properties window, verify that Modem - Standard Modem is selected, then click Configure.
  11. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK.
  12. In the Properties window, click OK.
Task 4
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Click Start > Settings > Network Connections > <name of your new connection>.
  4. Type the user name and password provided by your service provider.
  5. Click Dial.
Apr 07, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Cell phone (LG KP199) to PC (Win XP) USB data transfer problem
When you connect your phone to the PC, it shows two options for connecting: Mass Storage and Cell phone. Select mass storage.
For connecting in Cell phone mode you need to have the PC Suite for this model which as on date is not available.
You can use any third party softwares like mobimb, Mobtime Cellphone manager etc. for connecting to PC.
Dec 30, 2008 | LG KP200 Cellular Phone
New dell studio desktop will not connect to internet with Vista
Turn off the Windows Firewall and the firewall software (Windows Live one care) and you should be able to connect to the Internet without any problems
Dec 27, 2008 | Microsoft Windows Vista Ultimate Edition
BSNL Broadband with Windows Vista
To fix the issue in windows vista.Follow the stepss
1.Plug the usb modem 2.goto control panel > windows update. Windows update will find the drivers automatically and will install it..
Dec 27, 2008 | Computers & Internet
Unable to cnnect internet on vista home basic
check the NOKIA site for compatibility issues for VISTA. VISTA has compatibility issues with many softwares (which may include the improper driver for your N 72)
May 24, 2008 | Computers & Internet
I just bought a 4720. Iy has windows vista. I also have an old Toshiba sattelite with windows xp. To connect to the internet the toshiba works every time. The new acer sometimes does but mostly does not....
You will have several problems to install Windows XP in a computer designed to use Vista. I personally don´t think it´s fair.
But your problem possibly is not related with the OS. Are you using a wireless router? If yes, the problem may be your 4720´s wireless adapter (probably internal). You can test it by using another wireless network (most malls, shopping centers, airport or hotels have avaiable public wireless internet access).
Apr 19, 2008 | Computers & Internet
Driver for lg ku250 phone
its very easy to solve this problem, since vista have new driver management unlike old xp's which need external drivers for all new hardware installed on it, a vista does not.
-- just plug the phone in a data service mode. (on usb connection manager)
-- when vista ask for driver just let the vista search for it.
-- and choose LG xxx modems if asked.
Voila i connected to internet.
for pcsuite like managing sms i dont have solution.
i didnt find problems when accesing my microSD. my laptop recognize it as external drive.
Mar 29, 2008 | LG KG800 Cellular Phone
Connect LG Shine KE970 to Window Vista
Set the phone to Mass Storage.
To do this, go to settings, connection, usb connection mode, mass storage.
The computer should recgonize the phone and have it appear in My Computer.
Feb 11, 2008 | LG Shine KE970 Cellular Phone
Microsoft Windows Vista Ultimate Edition Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
