Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi WT-46809 Turns on with Power light then turns off
I own a Mitsubishi Model WT-46809, Serial 11382, 2001 September build, television which was working fine.  Now, however, when I power it on it:  makes it's click sound and the power light comes on, power light stays lit for a few seconds, then the click sound again and turns off.  I am unsure what this could be related to, as it made no indication of it's bulb burning out or anything.  I tried to unplug it from the power strip and into a direct socket to see, but to no avail.  Any ideas?
  • leno85 Jun 25, 2008
    My turns on but after 5min it turns off
  • butunome Jun 30, 2008
    my mitsubishi wt-46809 will turn on , about 5 seconds the tv shuts off.
    there is a thump sound when it turns off but that is a quick bass sound
    coming from the speakers. i think it might need a new power supply ??
    when it is turned on the bulbs look like they are trying to come on before
    the tv shuts off. need help , thanks , islesvikes4life@comcast.net
  • 51 Answers
There are 2 fuses -24v and 24 v normally would go out because
covergence ics failled . That would be a shutting down problem cased by missing those voltages.so you would need to replace those 5A (small green fuses) , you would need some kind of soldering and unsolderin skill) and the ics are stk392 570.two also. open the set from the fron ,taking speaker grill off and then the wood board behing (4-6 screws) you the the board in the center big metal heatsink. you would need to work from the back to repace those puppies.hdtvman
Posted on Jul 01, 2008
Mitsubishi WT-36809 turns on for 2 seconds and then turns off. The error code is 22. Any ideas?
Verify the model number. Some of these Mits. family have bad picture tubes, and oil spills out onto the signal board. Look inside front panel, RHS tube, look below it onto signal board. If you see an oil puddle, then tv is toast!
Jan 18, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-42311 green light flashes and turns
Mits are bad about power supply capacitors failing. It can be fixed fairly cheaply, but requires some skill at disassembly of the tv and unsoldering/soldering.
Dec 10, 2009 | Televison & Video
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi problem
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Oct 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Wont stay on
I can help u fix in live chat!
Mitsubishi WT-46809 46" Rear Projection Television Logo
204 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
