Question about True TD-95-38-LT Beverage Cooler
Sliding door replacement parts
I can't seem to find replacement tracks for my TD-95-38 / 3 door bottle coolers. Do you have any idea here I can find them?
Thank you so much for your time!!!
  • nealio2 May 11, 2010
    bar owner. more details please. i'm a little confused
  • brian l. Feb 03, 2012
    I also have a true td-95-38 3 door cooler and need the top door slides that the doors slide on and maybe the door slides themself that are attached to the door bottoms. I believe both are a black plastic.Looks like the door slides snap onto an edge and mine are broken from people sitting on them.
  • 3 Answers
I go to Home Depot to get their aluminum 'L' bracket (3 ft or 4 ft lengths, etc by 3/8th or 1/2 inch), usually by their screw and nail aisle. Depending on whether the rail you're fixing is on the box's outside frame edge or an separating inner edge, you'll need to turn the 'L' either up or down so that the screws to attach it have something to bite into. I also add a line of Gorilla glue to the aluminum and wet the edge it need to attach to for extra strength.
Posted on Apr 23, 2009
It is possible to take apart a Whirlpool wine cooler door to replace the tempered thermal glass unit inside. Door is stainless steel with plastic insert on inside with gasket in the plastic insert. I
It is likely a double glassed unit, You can try and slide a thin bladed knife like the snap blades between the glass and the rubber and cut it away., You may be better to take it to a glass company that make DGU (double glazed unit) and they will be able to produce another piece o glass for it and put it back through the machine to make it a new unit.
Aug 28, 2014 | Whirlpool 38-Bottle Wine Cooler
How do you change a evaperater fan on a Beverage air bottle cooler?
Its a pain but reach down in there and pull the screws out and remove the panels. Its in there honest! Hope this helps good luck.
Jul 12, 2014 | True TD-50-18 Beverage Cooler
The door light in wine fridge will not turn off when the door is fully closed..
There is a switch for the light. If it isn't a mechanical switch where the drawers slide in, it will be a magnetic switch in the edge of the drawer
Dec 27, 2012 | Haier Aficionado 26 Bottle Wood Trim...
We have a true upright, glass front beer cooler. TBB-4-G refrigerated back bar. The bottles and cans right in the middle are icing up and forming huge blocks of ice. we have turned up the thermostat,...
Check your evaporator drain pan and the outlet for the condensate water, and make sure the drain tubing is clear. That water is supposed to drain outside the box.
Aug 30, 2011 | True TD-95-38-LT Beverage Cooler
Wine cooler Doesn't work
I had the same issue on a Whynter WC28S SNO 28 Bottle Wine Cooler, it even seems like most of the thermoelectric wine coolers, fridges, and such have the same boards by hanny. For cross refference parts I used NTE because Fry's Electronics had them.
Switching transistors - NTE51
1N 4007 - NTE125
Silicon Dual Power Rectifier - NTE6090
Also I have a venotemp wine cooler that has pretty much the same board, with the same plugs for fans, light, control panal, and cooler fan for $45 shipped at their site under replacement parts. Hope this helps people looking for info on this. Also research Switching Power Supply issues for information.
Oct 26, 2009 | Refrigerators
My sliding patio door is sticking
usualy there are 2 ajustment screws at the bottom in the flashing
if you lift the door out of the track and look at the bottom you will see the rollers and likely the ajustment screws is there are no adusters make sure the rollers are free f not spray with penetrating oil and let sit untill free then try again
if sash or frame is tight try spraying it with pledge furnature polish the light grease coat will allow plastic parts to move freely once again
Jul 23, 2009 | Locks & Locksmithing
Problem with a True TD-50-18
That is the drain which may be clogged. Look for hose in pan by compressor and use one of those cans of air to blow out computer keyboards.
Apr 26, 2009 | True TD-50-18 Beverage Cooler
True 2 door light problem
I believe that unit has a ballast tucked in somewhere in the compressor compartment. It may be easier to access from the back of the unit. I don't think it has a starter.
Dec 09, 2008 | True TD-95-38-LT Beverage Cooler
True TD-36-12-S Bottle Cooler
1st check the outter coil and make sure you can shine a flash light through the coil. If not blow out with compressed air and look again. A dirty coil may be your problem.
2nd check the inside coil it may be blocked with frost - ice
3rd the fan both in and out have to be running.
4th check the door seals
you could be low on refrigerant or have a bad thermostat but eliminate all else before going to these 2 problems.
Sep 16, 2008 | True TD-50-18 Beverage Cooler
True TD-95-38-LT Beverage Cooler Logo
446 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
