Toshiba Satellite M105-S3004 Notebook Logo
Posted on Jun 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop LCD won't display
Boot up my laptop, LCD won't display. Plug in external monitor and press Fn+F5 switch to external monitor and works. Press Fn+F5 switch bak to laptop LCD but no luck. Appreciate if you can help?
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Jun 08, 2008
Anonymous
Master
Level 3:
Answers
458
Questions
Helped
242804
Points
1345
Bad Video.... It is replaceable if you have dedicated Video,
Need to replace the motherboard if you have onboard (integrated)video..
Not able to connect to projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
1helpful
How to connect an external monitor when your screen stay whiteMy screen stop working and i don`t see to configure external display!
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
4answers
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Can I use the vga port on my ctf 3271 lcd tv as a monitor and connect it to my laptop?
yes!
and use it as external monitor.
connect it and then both switch on
when the "unusable" displays
press FN key and F5 key
this will switch laptop monitor to external lcd monitor
Connect laptop to external lcd monitor
This laptop has a blue VGA port. Plug your monitor into it. You might have to adjust the BIOS to recognize the external device.
Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. The key sequence can vary depending on laptop, however is often either: Fn + F3, F4, F5,F8, or F9. This means if you were fore example to press and hold Fn + F3 at the same time it'd switch between your laptop display to your external display. The function key will often be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
1helpful
I have acer 3050 is switch on but no display
Hi! Try to check if there is a hotkey to turn on/off lcd display. If none, try to power drain the machine by unplugging ac adapter and removing the battery.Press and hold the power button for 10 secs and then after that put the battery back and plug in ac adapter.Press power button and then check if you will see anything on the screen,if still the same then try to connect the laptop to a external monitor and then press FN+F5 to switch display to external monitor, if you see something on the ext monitor it means you are dealing with a faulty lcd on your laptop...Hope this helps...
When I connect my aspire 5315 to the tv and boot the computer it shows the boot on the tv but suddenly stops when the computer comes up and does not show the monitor again. I press Fn f4 and nothing...
Fn + F5 is what changes external display mode on acer laptops. Press and hold Fn, then press and release F5 to change between three modes:
Laptop display only.
Both displays.
External display only.
OR....
You need to go into your display properties and extend your desktop onto the external monitor. If this doesn't solve it, let me know :)
2helpful
2answers
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
1helpful
Swithcing from laptop screen to lcd monitor
Hi
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. video.gif For example, often either Fn + F3, Fn + F5, Fn + F8, or Fn + F9 is pressed to switch between alternate displays. So if your laptop was Fn + F3, pressing and holding both Fn and F3 at the same time would switch between displays. Often, the alternate key pressed in conjunction with the Fn key will be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
1helpful
Use of fn5
plug your external monitor cable to your laptop.
when you press Fn (hold Fn) and then press 5, for some model it give you choisee (display on lcd, lcd+monitor, monitor). to select the choisee you just press 5 again (you need to hold fn key)
if it still not working, plug your monitor to your laptop and boot.
ussually it work.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
