Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
MY GARAGE DOOR KEEPS OPENING AND CLOSING. AND ONE OF MY SENSORS IS ORANGE INSTEAD OF GREEN. WHAT IS THE PROBLEM?
    Problem Solver:
  • 15 Answers
As I have mentioned in other post, re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Posted on Nov 01, 2010
2 Suggested Answers
  • 3197 Answers
SOURCE: I have liftmaster professional garage door opener.
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Posted on Oct 25, 2010
The sensor light are different colors
The sensors are seeing something directly in line with the beam between the 2 sensors, or your sensors are not aligned so they point directly at each other.
Jan 12, 2013 | Craftsman Sears Liftmaster Garage Door...
Garage door will only shut if I hold down wall button, sensors are aligned, one is green, one is orange, this happened after a lightning storm
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Jul 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
On the sensor for the craftman garage door opener 1 is orange and the other is green and my garage door doesn't open with the remotes
Nothing wrong with the sensors. They don't work when the door is opening anyway. Only when closing. Make sure the light in the wall control is not flashing. If it is press and hold the lock button for 3 seconds.
Dec 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP garage door opener, the left sensor is orange and the right sensor is green. the problem is that when i try to open the door, it only opens about a half foot and stays there. i...
Nothing wrong with the sensors and they only work when the door is closing anyway. Sounds like you may have a broken door spring or a bad drive gear. The drive gear is white nylon and is in front of the motor. It will be obvious if it is going bad.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light...
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Garage door is not opening or closing. One of
depending on model, both are green or one green/one orange. that is not your problem, however you really do not give me much to work with. "It does not work". Does chain move? Does motor run? What is you hold wall pushbutton? Give more info.
Apr 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Jun 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage sensor problem
The colour on the sensors doesn't change.
One is orange constantly and the other is green when detecting a signal from the orange sensor.
If the green is flickering, they are not adjusted correctly.Move the green sensor until you get a good solid green. Holding the wall pad button down, just bypasses the sensors.
Try adjusting only the sensors so that they are solid.
In addition, check the little yellow light on the back of the machine and count the flashes.
The number of flashes will tell you what the error is in your manual.
Jun 18, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
775 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
