Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Replacing thermostat replacing my home thermostat with a honeywell focus pro 5000. my present thermostat has a blue,green,red,white,yellow wires. the new thermostat has hookup for green,white,red,yellow wire and a c for common. what do i do with the blue wire? does it connect to the c common plug?
  • medvanrey Jun 23, 2008
    MY THERMOSTAT HAVE 5 TERMINALS OF WIRES,
    When I moved the lever to on position nothing happen, no power..
    The thermostat have 5 terminals, 4 colors as follows:
    GREEN..........1 wire
    YELLOW........1.wire
    WHITE............1 wire
    RED h is connected to RED c
    What may be the problem? PLEASE.
    What wires to test for power?
  • jv8404 Jun 23, 2008
    Me 2, everything is connected except the blue wire. My problem is that I cannot control the temprature. It will go up or down but will turn on.
It was hooked to the blue terminal on the old 1 but the old one was not a programable
Posted on Sep 19, 2008
YES THE BLUE WIRE DOES CONNECT TO THE C TERMANAL FOR COMMON
Posted on Sep 12, 2008
The four colors of wires, where or how do I install in the termostat?
Posted on Sep 03, 2008
    Problem Solver:
  • 8 Answers
What is the blue hooked up to now?
Posted on Jun 18, 2008
  • KennyD1976 Sep 16, 2008
    irritating how no one answers WHAT WAS THE BLUE WIRE HOOKED UP TO ON THE OLD THERMOSTAT?
Replacing Thermostat I'm replacing our current battery-operated Honeywell thermostat with a wifi Honeywell thermostat. Our current one does not have a c wire hooked up to it but it does have two unused...
The c in the furnace that is white is going to your condenser, it must stay. ADD the blue that goes to the tstat OR brown, which ever and then use that color on your new tstat and you will be fine. Always turn power off when changing stat
Sep 26, 2017 | Honeywell Heating & Cooling
RED BLUE GREEN WHITE ARE THE FOUR WIRES THAT I HAVE TO CONNECT. PROBLEM IS THAT I FORGOT TO (AND I KNOW BETTER) MARK WHERE EACH CAME FROM TO PUT BACK IN THE RIGHT PLACE -- USED TO HAVE A DEHUMIDIFIER NOT...
On the back of your thermostat, you should have a R (Red), W (White), G (Green), Y (Yellow), and a C (Common). If you have a thermostat that also has a set up for a heat pump, you will have additional terminals, but you don't have to use them since you have a 4 wire, ( in case you do, make sure your thermostat is set up for 1 heat, 1 cool). Your wires are all color coded besides the blue. Red to R, Green to G, and so on. Your Blue wire is being used for Yellow which will go to the Y terminal. Blue is usually meant for a common, but with only having a 4 wire, that's the color that was used. Red is your power, Green is your fan, White is your heat, and Yellow is your A/C. Hope this helps clear some stuff up and good luck!
Mar 12, 2010 | Honeywell Electronic Programmable...
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
Help! replacing WeatherKing thermostat with Honeywell RTH230B
RC AND RH CONNECT BOTH WITH RED
Y TO THE YELLOW
G TO THE GREEN
W TO THE WHITE
Sep 18, 2009 | Heating & Cooling
I'm installing a Honeywell RTH7600B programmable thermostat and replacing a Honeywell T87F2873. The new one calls for a Red, Green, White, and Yellow wire, while I only have a Red, Green White and Blue....
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
Jan 16, 2009 | Heating & Cooling
Thermostat wiring
L is for a common wire if t-stat does not use batteries then this wire will have to be connected
Jan 13, 2009 | Honeywell Focus 6300B 5-2 Days...
Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Jun 14, 2008 | Ruud UBHC Air Conditioner
Changing out home heating and cooling thermostat
Yes, the blue or yellow are interchangeable. they are for the cooling mode. Just first make sure the white is heat, green is fan and red is the power 24v.
Dec 17, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
503 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
