Question about Tomtom GO 720 GPS Receiver
TomTom Homepage on PC does not work
Whe i bring up the TomTom application on the PC - it does not respond to anything i do. Always says the connection to the server was lost. However my internet connection works fine with the web browser,
  • ROBERTSJD1 Jun 25, 2008
    CHANGE MY TOM TOM ONE BACK TO ENGLISH
  • algalgor Jul 02, 2008
    After connectin go PC, appears a red cicle with white X inside. PC does not recognize device.
    Albert. Thanks
Can not remove homepage,help
Posted on Jun 22, 2008
My tom-tom program has been delete
It is very common to get faults with the main program(application) on tomtom satnavs. Download the instructions from www.tomtom.com Connect your device to tomtom using your pc and tomtom home. It should update the application. On the web site is full instructions on reinstalling all the programs to the device however you will need to save your map and install it from this backup once application has been installed as you cannot download a new map without subscription or payment. Check the website for the latest post codes for your map and install it as well This is free. MAKE A BACKUP of the device first as if anything goes wrong you can reinstall the backup.
Oct 18, 2013 | Tomtom XXL 540S GPS Receiver
I have no pictures of cars on my tomtom I cannot change from an arrow to a car
Install ToTom Home on your PC, it is free on tomtom homepage,and connect the gps on it. Through Tomtom home you will be able to install voices, cars, lots of funny stuffs
Dec 06, 2009 | Tomtom ONE 130S Car GPS Receiver
No Application on my TOmtom go 720
Connect your TomTom to your PC and open the drive in "my computer". Locate the ttgo.bif. Copy and paste the ttgo.bif onto your desktop (do not skip this step in case something goes wrong) then go back to the TomTom and delete the ttgo.bif. after deleting ttgo.bif open TomTom home. It should then tell you you need a operating system. Let TomTom load the system. You may have to do this a couple of time to fet the latest operating system back onto your TomTom.
Aug 08, 2009 | Tomtom GO 720 GPS Receiver
I upgraded the tomtom via tomtom home and it will not start
Hello,  I own a TomTom also. I have listed the procedures from TomTom Home and hope this will work. First try a soft reset (Reset button is located at the bottom of the TomTom device next to where the DC plug plugs in). Make sure your batteries are fully charged up or the USB cord is plugged in.
If your device is not starting up properly, follow the steps below:
  1. Soft reset your device. *
  2. If your device still does not start up, then reinstall the TomTom application using HOME
If you have backed up your TomTom to your computer, then you can reinstall the TomTom application from your backed up data. *    In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
Jan 10, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom 1xl stuck on usb screen
Hold the reset button until you see it start up again. If this does not work plug it into a power source via USB and then do another reset.
Sep 19, 2008 | Tomtom One XL GPS Receiver
Tomtom keeps rebooting by itself soon after being switched on
Here is a solution that worked in my case (constant reboots after voice select)
  1. Plug your tomtom into your PC.
  2. Run TomTom Home
  3. Select the option to run your TomTom through your PC (TT Home)
  4. You should be greated with the select language screen
  5. Then simply select language etc.
  6. When you get to the voice selection: select a voice (here TTHome should freeze) <- also strangely enough notice the cancel button doesn't on the screen (as it does when doing this on the device)
  7. Don't panic TT Home should start working again in a few seconds
  8. Disconnect your TomTom and that should have solved the problem, the normal map screen should show up upon starting up your TomTom
This solved the issue for me, hope it does for you good luck!
Aug 22, 2008 | Tomtom ONE GPS Receiver
I am unable to connect my mobile
Reset your device
Reset your TomTom using a straightened paper clip.
If you use a PDA, check the manual that came with your PDA to see how to reset it.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
Jan 07, 2008 | Tomtom GO 700 GPS Receiver
Tomtom one
Hi Steve de may.
Try removing your SD card and inserting again. If the problem persists then I recommend you use your backed up copy to restore the SD card. You did make a back up on your PC, right?
The other possibility is that in the preferences section of you tom tom the wrong map has been selected or a map that it cannot read has been loaded. Remember newly purchased maps must be activated first before use.
I made a copy of may original SD card and use that in my tomtom. If anything goes wrong, I can always restore it from the original. I also made a copy on my PC using the Tomtom "Home" application.
Hope this helps.
Regards,
Spare head 2.
Jan 03, 2008 | Tomtom ONE GPS Receiver
MY APPLICATIONS & GAMES NOT RESPONDING
WHE I CLICK ON GAMES AND APPLICATION I WILL SHOW A MSG OPERATION FAILED. PLEASE HELP ME.
Dec 18, 2007 | Sony Ericsson K550i Cellular Phone
Tomtom GO 720 GPS Receiver Logo
224 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
