Question about Apple MacBook PC Notebook
Forgot password my niece turned the the screen saver and I forgot my password how do I fix the prblem
    Brigadier General:
  • 3,614 Answers
  1. restart your computer
  2. go to Control Panel
  3. click Display
  4. on the Screen Saver Tab, uncheck on Resume, password protected. i.efigA.
  5. click Apply, then Ok.
Enjoy
Posted on Jun 07, 2008
Dgm t-909 tablet my son set a formation password has either forgotten it or tried too many times and locked it. i tried the reset button and nothing happened
Hold down the power button and the up volume button at the same time for about 30 -60 seconds. The device should go to the factory reset screen if not use power on button to get to the screen. You will lose all data stored. I know this works as I have just done the same to my nieces as she forgot her password.
Dec 28, 2012 | Tablets & eReaders
I have a dell Insprion E 1505 and I removed all my data and files so I could give it to my niece to use. When you turn it on the windows screen comes up for a minute then a new user /password screen comes...
Hello.
Boot your system to Safe Mode again. Key in Administrator with no password. Go to System Restore and choose a date when your system worked OK. Add a new account for your niece.
Then, delete your data again.
Hope this helps.
Feb 27, 2011 | Dell Inspiron 15 (dndozm6_4) PC Notebook
If I leave my computer unattended for maybe 15 min. this monitor turns itself off. Is there a way to fix that? Thanks, brumeister
Screen savers can help protect your monitor from wear by showing a constantly changing display when your computer is not being used. Screen savers can be simple, like the Blank screen saver that turns off your monitor to save energy. To change your screen saver 1. Right-click your desktop, and then click Properties.
2. In the Display Properties dialog box, click the Screen Saver tab.
3. Click the Screen saver drop-down box, and then click a screen saver.
4. Click the Preview button to see how the screen saver will appear on your monitor.
5. Move your mouse or press a key to return to the Display Properties dialog box. To try a different screen saver, return to step 3. 6. Click the Settings button to change the standard behavior of the screen saver you selected. (Each screen saver has its own settings dialog box.) Then, click OK.
7. In the Wait box, type the number of minutes the computer should wait to start the screen saver after you last touched the keyboard or mouse.
8. If you are the only person who uses your computer and you are not concerned about security, clear the On resume, display Welcome screen check box. Otherwise, leave this check box selected. Note: If your computer is joined to an Active Directory, the Fast Users Switching feature will be disabled. This is a common change made to computers used for business, and it happens automatically when a computer joins an Active Directory domain. However, disabling the Fast User Switching feature is not the default setting. Almost all computers in home environments will have Fast User Switching enabled. When Fast User Switching is enabled, you'll see the On resume, display Welcome screen check box. If you're part of a domain, you'll see the On resume, password protect check box.
9. Click OK.
Jan 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Forgotten Password
when booting after the post (beep) press the F8 key and load in safe mode. from there try and login as Administrator, 99% of computers have no password for that login. if you have the welcome screen just click on it, if you have the network login type in "Administrator"
from there you can goto the control panel access the user accounts and change/remove the passwords (this is based on the idea your computer is running xp/vista...based on data from hp i'm going to guess XP is what your running)
Mar 12, 2009 | HP Pavilion dv6000z Notebook
Forgot my screen saver password
You need the Install CD that came new with your computer to reset the password if no other administrator accounts have been created. Steps:
  1. Tuin on your computer, Insert the Install CD on your computer and hold the C key
  2. Choose Reset Password from Installer/Utilities Menu
  3. Select your Mac OS X hard disk volume.
  4. Set the user name of your original administrator account.
  5. Enter a new password.
  6. Click Save.
  7. Computer restarts and you now know what your password is
Jun 07, 2008 | Apple MacBook PC Notebook
Idk dat passaword
i think its asking for the screen savers password what u do is restart the system if its screen saver ten it will go off. so u will have to go and disable it by right clicking on an open area on yr desktop then click on properties then on screen saver.
thank u
May 22, 2008 | Toshiba Satellite A135-S2276 Notebook
How to by-pass windows' screeensaver password
hi dear
in the login box
press ctrl+alt +del
fill user name : administrator
and left the passord blank
enter
oke
cropp
Mar 21, 2008 | Toshiba Satellite A60 Notebook
Screen saver password
There is no Screen Saver installed on the MobilePro 900C. The Password screen can be used to password protect the desktop.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Apple MacBook PC Notebook Logo
89 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
