Question about LG WM-2277HW Front Load Washer
LG Front-Load Washer WM2277HW ce sign
I have a LG WM-2277HW Front Load Washer
It stopped working with ce showing.
What is the problem?
  • Anonymous Jan 31, 2009
    I have the same issue, I replaced the stator a few months ago along with the attached parts. I have tried switching out the other parts to see if one of those was bad but still get no power to the unit at this point. Was initially getting the dreaded LE error and got that solved with the stator and parts I replaced a few months ago. I did smell a very brief electric burning from the back of the unit when it went out, but am unable to see anything that actually burned out. Of course making it harder to diagnose. I am thinking the main Power board is the cause at this point as this is where the smell came from. Any help would be great.
    Paul
  • Anonymous Mar 16, 2014
    lg wm-2277hw mold in detergent tray
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Posted on Jun 08, 2008
LG Tromm WM2277HW drum was noisy, then wobbly and now has stopped spinning
Remove back cover and check for a loose nut that holds the rotor. you may have to replace the rotor( is the cover that holds the magnets). Not the stator (which is the motor.)
Apr 28, 2014 | LG WM-2277HW Front Load Washer
Is it a big job to replace the bearing on a WM2277HW front load direct drive washer, and what kind if tools would I need.
quite a task if you have never done before . have a look at utube.com this will show you generally how to fit a drum bearing alot of time its simpler to replace machine
Feb 10, 2011 | LG WM-2277HW Front Load Washer
Does a pedestal for the 2005 LG WM2277HW fit the newer models of LG Front loaders?
Yes, it can be used, but the fastening system for pedistal to washer is much better with the new pedistals.
Jan 25, 2011 | LG WM-2277HW Front Load Washer
Need to see diagrams for removal instructions for the drain pump on lg washing machine wm2277hw
LG WFS7012ds model washing machine while starting of washing operation after start 5 min machine geeting stopped with beep sound
Jun 21, 2010 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer not working with ce showing
Sgt 48
Jun 07, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
336 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
