Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
GE Profile GSS25SGMC BS
Fan runs in freezer constantly,does not cut off when door is open, coils freeze up, repair man changed a bad circuit board, and then the thermidistat. fan still runs constantly. What could this be?
    Problem Solver:
  • 6 Answers
Try door switches
Posted on Sep 23, 2009
  • frank563 Sep 23, 2009
    it could be that you have a bad door switch that is not opening the circut when the door is open.
4 Suggested Answers
aasc
  • 1606 Answers
SOURCE: IS THERE ANY SITE THAT HAS FREE REPAIR MANUAL FOR
ready ? Number 1 thermistor is located against the back of a U shaped chanel atop the left side refrig shelf mounting bracket beside the refrig damper . #2 is located 1/2 way down on the refrig right wall with a 2 " oval covering . # 3 you only have if you have a quick chill at the lower right side in refrig section . # 4 is clipped atop of the coils inside the freezer section . # 5 is located slightly foreward of the drain pan inside of a small capsule at the bottom of the freezer section . There is a way to check all thermistors useing the touch control board , but that was not the question you submitted .
Posted on Aug 30, 2009
Testimonial: "you gave out very GOOD directions Thank you"
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Arctica PSS25SGNA BS Icemaker is not
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Posted on Nov 18, 2009
SOURCE: My GE Profile PS123SGPA BS side by side keeps
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Posted on Feb 21, 2010
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Apr 24, 2012 | Refrigerators
I have a stainless GE profile PSS26SGPASS side by side fridge and suddenly the freezer and fridge wont hold the temp settign I put. The fan works, the controls work to lower the temp setting but it isn't...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 26, 2011 | GE Refrigerators
IS THERE ANY SITE THAT HAS FREE REPAIR MANUAL FOR GE SIDE BY SIDE REFRIGERATOR MODEL# GSS25SGMC BS, I'M LOOKING TO FIND WHERE THE THERMISTOR AT.
Aug 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Coil fan will not run.
Replace the master control circuit board on the rear of the fridge.
Jun 22, 2009 | GE Profile Bottom-Freezer Refrigerator...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not staying cold in the hot weather
Same problem as all of you. Mine happened at 17months old, not covered under warranty and cost just under $400 to have them replace the circuit board. Top of the line fridge and it is just junk! I am reading on blogs that there is a recall on these circuit boards but no one has yet to find where to call to get a free one. GE shouldn't be charging people to repair something that was bad right from the beginning whether it is past the warranty, or not. I just can't even underestand how you buy a top of the line product and you have a problem before it is even 2 years old.
I also bought a GE microwave at the same time, again, top of the line, $400 piece of junk, which I have also had nothing but problems with. It needed a new circuit board also within the first 6 months of owning it. That one was covered under warranty. Oh, and get this, the repairman had to order the circuit board rather than get me a new fridge because he says "this microwave is obselete now", are you kidding? it's 6 months old.
I WILL NEVER BUY ANOTHER GE PRODUCT AGAIN!
Jun 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
516 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
