Question about Everex StepNote VA4103M Notebook
Powering down my laptop keeps shutting off on me
  • Everex Master
  • 19,396 Answers
When this happens usually all you have to do is re-installing Windows. If you have the recovery disk (or you have recovery partition), you can perform a system new installation using the recovery disk. Usually you need to restart the computer with disk inside.
If you do not have recovery disk you will need to get a windows setup disk.
In some less frequent case, when you have this problem, you may have a faulty hard disk, in disk case you should also replace the hard disk drive, which is not an expensive part.
If you need to recover your data, you can try to perform a partial recovery.
If you have important data and you don't want to risk losing your data you should go to a repair shop and have the job done in the proper way.
If you are in north London, UK you can give me a call, we do it for about £60.
Posted on Jun 07, 2008
My Toshiba Satellite s55t - 5237 laptop won't shut down the cursor just keeps calling but doesn't shut down all the way
Press and hold the power button until it shuts down, On rebooting run safe mode first then reboot in normal mode.
Nov 30, 2015 | Toshiba Computers & Internet
Toshiba laptop satellite L645D-4040 keeps shutting down
does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
Oct 04, 2013 | Computers & Internet
Asus k52f keeps shutting down randomly
I have seen the odd case where the power supply cannot keep up with the demands when the laptop is running causing it to shut down, but first! remove the main battery to see if that helps, no change! I recommend replacing the power supply adapter in hopes it will correct the problem. Go to Type make and model of laptop, refine search to power supply and go through the list of prices.
Jul 20, 2012 | ASUS K52F-BBR9 Notebook
Laptop just keeps shutting down and won't turn on
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
Jun 19, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
Why sometimes i shut down my window but the word "shut down" keep appearl and cannot finis shut down...
Then, you should keep on pressing 'Enter' on the keyboard, perhaps it will finish shut down...or you
can turn off the power link, this is a silly question that you have made but i am glad to slove this to you. :)
Jan 21, 2011 | HP Mini 1000 Netbook
Shut down itself
Hi i'm Rain.
If your Laptop is over heating you may need to look into a stronger type of cooling system { Fan }
But for now lets set up your power Options settings
to try to keep your CPU cool.
In power options select Power Saver.
If you see the selection to keep the fan running select it also. save and exit.
Hopefully this will help to keep your system cool until you can service it.
Nov 25, 2009 | Compaq Presario Notebook
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Abnormal shutdown
This could be a hardware fault. Your power button could possibly be getting stuck whe you turn it on. This message only comes up when you maually hit the power button on the laptop. When it comes up again, try pushing the power button quickly to loosen it up, then hit cancel and wait to see if it happens again. If it does you will have to get your power button looked at.
Jul 05, 2008 | Apple MacBook Pro Notebook
Everex StepNote VA4103M Notebook Logo
Top Everex Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
