Question about Hobart A200 Stand Mixer
C100 i was given a c-100 and i have no attachments,i looking for a dough hook and a paddle. i am also wondering if there is a way to grease the gears they sound rough.
  • llcrawfo Nov 17, 2008
    Our school has an old C-100 mixer----still works superbly, but is missing the dough hook and other attachments. Any solutions? thanks! L Crawford
  • cowboy832 Nov 28, 2008
    I need accessories for my hobart c-100 mixer to.
  • 640 Answers
Parts are no longer availiable for these units as they are old.You may be able to find something online like ebay ect,ect.I work for hobart as a service tech and havent repaired one of these units in 15 yrs.
Posted on Jul 19, 2008
No i'm only looking for attachments for my kitchenaid mixer model no. ksm90ww
State your country and someone will direct you. What is a batter blade, is that the flat paddle or a dough hook?
Jan 08, 2015 | KitchenAid Food Mixers
The dough hook on my KitchenAid Classic no longer fits on the shaft.
Get a round file and gently rasp it out, you are trying to remove the build up in the hole not rasp the metal away. Flour dust gets in the hole and embeds itself into the soft metal of the dough hook. Also clean the shaft if you can see any dark patches on it. The shaft is good quality steel so you can use fine sandpaper on it without really removing any metal. It's not uncommon for a paddle or a hook to become frozen onto the shaft from flour dust getting in there while mixing. The first time I encountered it I had trouble convincing myself the flour was the problem, I've seen enough of them now to know that's what it is.
Nov 17, 2017 | KitchenAid K45SS Classic Stand Mixer
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Grease for hobart c100
If you mean inside the gearbox then you need gear oil. Ask for it at a restaurant supply. if you mean grease for around other moving parts remember that it would be wise to find something that is food grade in case it gets into your product.
Oct 15, 2013 | Hobart C-100 10 Quart Mixer
When making bread dough the mixer dough hook jammed. now the mixer makes a terrible racket when used and will not mix heavy loads, ie dough.
In the mixer there is a worm drive gear, it is a fail safe so that you don't burn up your motor in just this insatance. the gear is nylon and when the machine is torqued too much the gear is designed to give out or strip. It is making a terrilble racket because all those chewed up teeth are now being milled and ground up while you are trying to use your mixer. STOP!!! the part costs about $8.00 USD and takes about two hours to fix. You should put a new gasget in but a lot of people dont want to spend the extra $6.00 buck because you have to buy new grease for this fix also, about $25.00 more. You must clean out all the old gear grease to make sure all the chewed up gear teeth atre out of the machine, then repair with new worm gear part and then re-pack with grease and add the new gasket and close up the machine all fixed. about 3 hours time $50.00 and a roll or two of paper towels. (The grease is real messy)
Sep 14, 2012 | KitchenAid K45SS Classic Stand Mixer
I can hear the motor running, but the attachment does not move.
Sounds like what happened to my wife's mixer. There is one nylon gear in the drive assembly that is designed to break if too much load is put on the mixer. Like what can happen with dough or butter that is too hard/frozen. That is designed to save rest of the mixer. Sounds like you need to replace the KitchenAid Mixer Worm Drive and Pinion Gear Assembly. In our case, it was not the nylon gear that broke, but a small pin that is this gear assembly. By getting the assembly & not just the nylon gear, you cover more of your bases. I found a video on line that walks you through replacing the part. I also bought the part online. The assembly part, including shipping cost me $12.95.
Hope this helps.
Nov 30, 2011 | KitchenAid K5SS Heavy Duty Commercial...
MY kitchenaid mixer has always oozed oil but suddenly today I can no longer attach the dough hook. The spring doesn't want to move enough for me to attach it. It was fine yesterday.
The oil that is "oozing" is actually grease. If it is laying on its side the grease will leak out but isn't really an issue. If it is leaking while the machine is right side up, it usually means you have a problem with the seal. When it comes to the spring not bending allowing the attachments to lock onto the shaft, that is a bizarre problem as the spring is just tension and isn't internally attached to anything inside the machine. If you want you can replace the planetary gear but that seems a bit drastic just for the spring. We usually recommend 1800Parts for parts and accessories because they carry EVERYTHING! So the seal they might have but I would bring the machine to someone to look at the planetary gear to make sure everything is in working order. If you are in New York you can bring it to us.
Sep 15, 2010 | KitchenAid K45SS Classic Stand Mixer
I have a 7qt mixer and would like too obtain some parts. Dough hooks mixing paddle etc. The model #A717
Try this site:
http://www.kenwoodworld.com/en/Products/Kitchen-Machines/Attachments/
Jul 03, 2010 | Food Mixers
No sticker/model number on the bottom of my stand mixer and am missing the paddle attachment and dough hook.
Since you have not given a make...I'll take a stab in the dark and bet you have a kitchen aid...simply because you mentioned the dough hook. Kitchen aid has 14 models of stand mixers. You can match yours up and look at available accessories at www.kitchenaid.com
Sep 01, 2009 | Food Mixers
Hobart A200 noise
Your mixer was built in 1942 and from the sound of it, it's been without grease for some time. Before you dismantle it, try adding new grease to it. This is the less expensive and less time consuming approach. The grease product to look for is Shell Darina XL EP-2, Try to find a local Shell Distributor and see if they'll sell you about 4 tubes of 400 grams each. This grease is compatible with most other greases, so you won't have to remove the old grease before you add the new stuff.
Remove the four screws that attach the Hub to the body of the mixer, pull off the hub. You now have access to the transmission area. work the new grease into the cavity, try to get as much grease as you can toward the back of the compartment. This will be a very messy job unless you have, or acquire a grease gun that the tubes will fit in. Lay the mixer on it's back and let gravity help you to get a lot of grease down through the hub opening. Keep adding grease until you've greased up to the hub opening. Grease the hub gear and then re-install the hub. Raise the mixer to vertical and start up the mixer, letting it run for a couple of minutes. Stop the mixer and shift gears,, once again start the mixer and repeat this procedure for the last gear. Listen for the sounds it was making before, they should be silent or at least muted. If it's still making loud noises, You may well have to take it apart for an overhaul. Dont overlook the planetary gearing, this gearing is not bathed in grease like the trans. Remove the planetery assembly, clean and inspect the planetary gear and the large ring gear in the mixer body. Regrease both and re-assemble. Your mixer is now as quiet as it will get short of a complete overhaul. If this solution works, it has only cost you a few bucks and a bit of time, making this. solution a good one, unless you still have the major noise issues.
I f you've found this solution helpfull, please rate it and Good Luck! ricardok45
Nov 26, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
122 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
