Question about Dell Latitude D600 Notebook
E-mail server I have been with at&t for ever then at the first of the year I had my internet connected but I never went though the process of doing the set up.When I am on a web page and I clickon their e-mail I don't have the correct server address and it comes up with an error.I need to know what server do I use?
  • 3,940 Answers
Without more information about you account, all I can do is point you here:
http://helpme.att.net/yoursettings2.php?current=%2Findex.php
Posted on Jun 08, 2008
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Feb 24, 2011 | Xerox WorkCentre M118 Black and White...
Networking
U must use Windows 2003 Enterprise Edition for mail server. To create a mail server u will need Exchange Server 2003 to install Server...
U will also need a router in it configure NAT and a lease line connection to start ur mail server
May 01, 2010 | D-Link AirPlus DI-524 Wireless Router
Yahoo mail too slow
since you are not able to access yahoo mails it might be for internet connection speed
incase that is not the case try to configure your outlook or ms outlook with yahoomail
Yahoo Mail offers standard POP3 access for receiving emails incoming through your Yahoo mailbox, by using your favorite email client software. To setup your email client for working with your Yahoo account, you need to select the POP3 protocol and use the following mail server settings:
    Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (port 110)
    Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (port 25)
tell me if this works
Apr 30, 2010 | Yahoo Mail
Tried to send e-mail error host SMTP could not be found error code ox8oocccod do not understand what that means
It sounds as though you're using Outlook to send email to and from and ISP and not to or from a Microsoft Exchange server. If so, then the following applies.
The error message means that there is a configuration problem with your email account settings. This error usually happens when an error has been made when specifiy the name of the outgoing (SMTP) mail server.
Note: It may be necessary to contact your ISP to obtain their specific mail server information. The standard port number for Incoming mail (POP3) is 110. The standard port number for Outgoing mail (SMTP) is 25.
Here's what you need to do to verify your settings:
1. Contact your ISP to obtain their specific mail server settings.
2. Open Outlook
3. Click on the "Tools" menu item then click on "Account Settings".
4. Make sure you are on the "Email tab" of the account setting dialog box.
5. Double click on the email account that is listed under "Name".
6. The Internet Email Settings dialog box will appear.
7. Look for the heading "Sever Information". Below that heading you will see Incoming and Outgoing Mail Server . Verify the names of your mail servers match the information given to you by your ISP.
8. If your ISP have provided you with port numbers other than those listed in the note above, perform steps 9 to 12. Otherwise proceed to step 13.
9. From the Internet Email Settings dialog box, click on the "More Settings" button.
10. Click on the "Advanced" tab.
11. Change the Incoming and Outgoing mail server ports to match the information provided by your ISP.
12. Click the OK button to save the changes.
13. Click on the "Next" button.
14. Click on the "Finish" button.
15. Click on the "Close" button to colse the account settings.
Outlook will now be configured properly to send and receive Internet Email.
Sep 13, 2009 | Microsoft Office Home and Student 2007...
What incoming and outgoing mail server info. do I need to set up
Hi, For yahoo mail you need upgrade to yahoo mail plus (@ $19.99 per year) to get the full pop3 service for access to Outlook,Incredimail, Thunderbird and others.
For more info on setting up your pop3 account see the links below.
http://help.yahoo.com/l/us/yahoo/mail/cl...
* Incoming Mail Server (POP3): plus.pop.mail.yahoo.com
Use SSL, port: 995
* Outgoing Mail Server (SMTP): plus.smtp.mail.yahoo.com
Use SSL, port: 465, use authentication.
If you have “yahoo.co.uk” address some users can get free pop forwarding see below.
Click “options” (top right) on your mail page>mail options>pop and forwarding>
Set up or edit pop & forwarding>type in the address you want to forward to and
click save.
* Incoming mail server (POP3): pop.mail.yahoo.co.uk
Use SSL, port: 995
* Outgoing mail server (SMTP): smpt.mail.yahoo.co.uk
Use SSL, port: 465.
Note: In order to be able to send emails from outlook and others through/to yahoo (pop3) you need to pay for a yahoo mail plus account.
http://help.yahoo.com/l/uk/yahoo/mail/cl...
Apr 10, 2009 | Yahoo Mail
"Can't connect to email server, make sure you have an Internet connection"
Whenever a mail server is unable to process an e-mail request, the e-mail fails and the software displays one of the following error messages: Can't connect to email server Progress bar stuck at 0% To resolve this problem go to http://www.kodak.com/go/itg
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
E-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Dell Latitude D600 Notebook Logo
178 people viewed this question
Alun Cox
