Question about ASUS P5RD1-VM Motherboard
Drivers my computer crashed and i had to install a new xp program but i cannot get my internet to work to finish installing the rest. how do i get my internet to work on it my motherboard is a 775 pin asus p5rd1-vm
Sir,
My computer in logon time logon is seccessfully but after a five minutes that shutdown automatically what's this prob? pls sir tellme and help me .... I waiting for your's ans..
On respectly kasif
Posted on Jun 07, 2008
Drivers not compatible with window 7
Hello Witonada, what type of driver issues are you having, Windows 7 comes loaded with a compatibility assistant that will install native xp or vista drivers for windows 7. to do so put the driver on your desktop, right click and choose the capability assistant then select try recommended settings, This option allows us to test run the program to see if the new compatibility settings fix the issue. Click on Start the program to begin testing it out. After testing the program and determining if the settings work or not click on Next. This will finish your new installation. In some instances the assistant may ask if the program worked in another platform say yes and choose windows xp sp3. walla your all set .
May 25, 2011 | Computers & Internet
I want window vista BUT I DONT KNOW HOW CAN I DO THIS
Hi there !
So tell me, what do you want to do with your computer? Do your computer crash and need to reinstall your Windows Vista operating system? Or you want to upgrade your operating system from Windows XP to Windows Vista.
For reinstalling Windows Vista, is it the same procedure when reinstalling Windows XP and Windows 7. Here is the link on how to reinstall operating system http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean. For Windows Vista, here is the procedure on how to reinstall Windows Vista.
1. Just put the installer CD into the CDROM Drive and open your computer
2. If message appear to press any key to boot from CD. Press any key to go to Windows Set up.
3. From there, just follow the installation procedure and put CD key if prompted and it will install itself the whole process. It will reboot for 3 times and don't press anykey when this happen. it will be finished within 20 mins.
For upgrading from Windows XP to Windows Vista, remember that all your files and softwares will be remove except for the hardware drivers. But not all the hardware drivers will be 100% working because upgrading the operating system will make your drivers outdated or not compatible with Windows Vista. If some drivers not working, just install the hardware drivers compatible with Windows Vista.
Here is the procedure.
1. Do not put the Windows Vista installer CD yet into the CDROM drive.
2. Open your computer and let it run to Windows XP program until is is finished to load your Windows settings.
3. Now insert your Windows Vista installer CD to the CDROM drive, it will pop up the upgrade installation wizard and just choose the upgrade installation. It will run the upgrading installation and just follow the instruction and it will be finish with 20 mins.
I hope this will help you and thank you for using FixYa !
Jan 07, 2011 | Computers & Internet
Can not locate net work adapter
Possible cause:
The hard drive contains all the necessary drivers that makes the computer function and that includes Internet connection. When you installed the operating system and all other software it does not mean you installed the driver for the motherboard which contains the drivers for the LAN.
Solution:
Run the drivers CD that came with the motherboard. If you don't have the CD. contact the PC manufacturer for the driver CD. Otherwise, you can purchase an add on NIC(network interface card).
Mar 20, 2010 | Computers & Internet
Is there a fix for Windows XP Home SP3 crash? my computer crashes all the time, i can format but i thought that there may be a fix because this is a known issue and many people have the same problem. If...
To make it short, you can try un-installing SP3, but the reason you computer is crashing is due to a program that is having incompatibility issues. That doesn't meant that your programs can run on SP3, it mean your programs and maybe even your drivers were install when you had SP2 and they didn't like the service pack update. You can definitely try to find which programs or driver are causing the problems but I recommend. Do a full format(non quick) and then a fresh install of windows and then update windows, and also try to download the latest drivers from the manufactures website and then install your programs.
**So yes I recommend an operating system re-install.
May 14, 2009 | Microsoft Windows XP Home Edition
Major HP crash
i think you got the wrong disks man, nothing to do with the motherboard.
a clean installation
it is recommended to this service at least
once every 8 months, it wipes all your hard
drive from data, programs, bugs, errors and viruses
this will 100% solve your problem guaranteed.
for xp, insert the xp installation disk
restart the computer and a message will
come up asking to press any key to boot
from cd. once you do that "i mean you press a key"
then a blue screen will load then asks you
to press Enter to install xp.
1. press enter
2. select the partion and press enter
3. select continue "it warns you to delete files"
4. select format "quick"
5. now let it do the rest and follow instructions
6. when the installation is finished you'll notice
its like new again, some computers will need
drivers which you can get from manufacturer
website. download and install them.
that's it but for a detailed information click here
Mar 08, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Trojan virus on new Dell Inspiron 1525 - VirusMelt by name
1. press enter
Mar 07, 2009 | Dell Inspiron 1525 Notebook
Trend micro internet security 2008
Dear Sir/Madam,
This error will appear if you have installed the 16.05 version of
Trend Micro Internet Security Pro, Trend Micro Internet Security and
Trend Micro AntiVirus plus AntiSpyware 2008 on a computer running
Windows Vista with Service Pack 1 or Window XP with Service Pack 3.
The Trend Micro Personal Firewall and the Unauthorized Changes
Prevention features main components do not work with the new service
packs from Microsoft.
A working version of Trend Micro Internet Security Pro, Trend Micro
Internet Security and Trend Micro AntiVirus plus AntiSpyware 2008 with
Windows Vista SP1 and Windows XP SP3 would be released sometime in
February 2008.
The release would be timed before Microsoft uploads the new service
packs in their automatic update servers for Windows.
To prevent this message from appearing, follow the steps indicated
below:
a.Check the program version of the Trend Micro program installed on
your computer.
b.If you are using version 16.05 and you want to continue using this
latest version of the Trend Micro program, you must uninstall the non-
working service pack from Microsoft.
c. If you do not want to remove the new Microsoft service packs, Trend
Micro suggests that you uninstall the Trend Micro program installed in
your computer and install PC-cillin Internet Security 2007 until the
release of the working version.
Thanks
Good Luck
“Don’t Forget to rate the Solution”
Jun 06, 2008 | Trend Micro PC-cillin Internet Security...
Canon MF5550 printer driver for Windows Vista
I just found this solution TODAY! After trying for a whole year to fix this thing... It was right at my face the whole time!!!!
1) Uninstall your old Canon MF5550 driver.
2) Reboot your computer
3) Download the Canon MF5550 driver Windows XP version.
4) Open your Vista Control Panel, then click on PROGRAMS (not on Uninstall or something else...)
5) bellow "Programs & Features", click on "use an older program with this version of Windows". Follow the wizard.
6) Locate the program manually. (If you need to search the folder where you downloaded your Canon driver, just go to search file on C. It will probably download on your desktop or Downloads)
7) Open the MF5550 Folder where you downloaded the driver, and click on the setup.exe file.
8) Choose on the next screen Windows XP
9) If you need to change the display settings, go ahead. But I didn't change anything. I just clicked NEXT.
10) Fill in the box: RUN THIS PROGRAM AS AN ADMINISTRATOR and click NEXT.
11) Click Next again and let Windows Vista do its job.
12) If it worked... just click yes and finish. If it didn't, click NO and run it again.
I AM SO HAPPY THIS THING WORKED!!!
Let me know if this worked for you!!!! I know I've looked everywhere for this solution...
email me at music2harvest@msn.com
GOOD LUCK! GOD BLESS!
Apr 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Computer crashed
by unplugging the adapter has not solved your problem because the driver is the cause of the crash. Try booting in safe mode again, but this time select last known good configuration, or boot in VGA mode(when in VGA mode uninstall the driver in add/remove programmes), if you get into last known good configuration your pc is working as normal. If none of the above work you may have to use your XP cd to do a system repair, if so post back
Sep 30, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
ASUS P5RD1-VM Motherboard Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
