Ac water leak
My ac has been clean recently now i have water driping, the drain line is clean,the pan is clean but the insulation near the pan gets soak wet and it leaks. coul some one help me
  • Anonymous Jul 23, 2008
    I have water accumulating in the styrofoam pan and also out side of the pan in the base of a GE model Zoneline 2100. It takes a couple of days for the water to get to the level where it overflows on to the floor. No problem with cooling.
3 Suggested Answers
MrARCADIAN
  • 284 Answers
SOURCE: water leak
Theres not much you can do the prevent condensation forming on the pipes of an AC(which is normal, the AC is probably forming alot of ICE (frost) and melting quite fast.
you could put the AC in and 3 degree angle pointing down so the water can travel in the direction you want it to flow.
That might make it work.
The drain pipe if its clean then you have the let the water accumilate ir you could make like a small funnel out of aluminum foil and place it where the water dripping, or try to cover the insulation with foil tape so the water does not hit it.
That might help also.
Posted on Jun 07, 2008
  • 3422 Answers
SOURCE: water leak
HI,
Please CLICK HERE for some very useful info.
This is a very common problem that is easily solved. The way your air conditioner dries your house is by removing moisture. That moisture must go some where. The moisture is removed by condensing it on the cold refrigeration coils and letting it run down a drain pan.
The problem is that dirt and crud will stop up the drain line and clog the pan. This will eventually happen to every system out there give it enough time.
While this problem makes a terrible mess and seems like to end of your system it is really quite easy to fix. Most system simply use a 3/4 inch PVC pipe to drain the water to a floor drain or sink. when (not if) this drain clogs the drain pan over flows (especially when the fan stops) and you have a mess.
Fixing this problem is rather easy. Simply take a wet dry vacuum and **** the drain line clean, 9 times out of 10 this will fix it and that is the last of this problem you will have for a few years. If the drain pan is really dirty then you will have to take the covers off the unit and vacuum it out. In extreme cases you may have to use compressed air, nitrogen or CO2 to blow out the drain line (expect a big mess at the other end).If you don't have either avaliable you can use the Garden hose to flush the line backwards (expect an even bigger mess on the other end)
In rare cases you may actually have a hole in the coil drain pan in which case the coil or the pan will have to be replaced especially if it is steel (but this is rare). In other rare cases we have had situations where grease or oil fumes from the furnace have condensed on the coil and caused the water to fall off the coil. When this happens you must clean the coil with soap or some solvent.
If the coil is totally stopped up the back pressure from the fan/blower can force the water out of the pan by undermining the bottom of the coil. When the coil is this dirty the coil usually needs to be replaced. You will also notice little or no air flow.
In most cases these condensate leaks are a do it yourself repair. Only if you must take the unit apart and can't, do you really need to call for help.Here is a device that will allow you to clean the drain with ease and
not have to take it apart each time.
Goodluck,
Please don't forget to rate or accept the solution
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Water leak
HI,
Goodluck,
Jun 07, 2008 | Heating & Cooling
My handler is leaking. The drip pan has a little water in it, I see a slow drip outside during operation. Near the blower water is coming out of one of the air ducts.
Hello, most likely you have a clogged condensate drain or a cracked or leaking condensate pan. First use a wet/dry vac on the outlet of the drain line, this will usually unclog the line. If the line appears to be clean then the pan will have to be replaced.
Sep 27, 2011 | Heating & Cooling
There is water leaking out from the bottom of my furnace. It leaks whenever the ac is running.
Hello, sounds like a clogged condensate line or a faulty condensate pump if the unit has one. Cleaning the drain line should fix the problem.
Jul 12, 2011 | Heating & Cooling
My PAC C110 air conditioner leaks a lot of water why?
Water leaking due to:
1. Non insulation of copper pipe lines.(Insulate with insulation material) 2. Dust blocked in drain pan. (Clean it) 3. Cooling coil and air filter blocked. (Clean it)4. Airlock in your drain line. (**** air from your drain line)
Dec 25, 2010 | DeLonghi Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Jan 16, 2010 | GE Quiet-Aire Ductless Split System Air...
We have RUUD AC, in second floor , that has a white pvc ope connected to condensate drain. other end of this pipe is inerted into large pipe neanr wall. looks a drain outlet. In the middle of this white...
Hello, W/D here.
There are a couple of things you need to check:
Look at where the drain connects to the A/C unit. There should be another pvc line right next to where the drain connects. This is the clean out/flush line, and is used for adding algeside to the tray internally, which thens go out the drain. Most importantly, there is a 1/8" hole between them, and usually, it's very hard to see. Make sure that this hole is open. If it is plugged, the condensate cannot drain from the unit while the unit is running and will create havoc with your drain system. The 'tee in the drain line is an air vent/vacuum breaker and can be used for a cleanout, but try the little vent hole trick first. Your drain line from the unit should be sloped to your house drain. If you do not have a clean out connection at your unit, then you can clean from the tee to the wall. Put one cup of white vinegar into the tee. It will work as well as bleach, without the corrosiveness of the bleach. If you have a cleanout on the unit, put the vinegar in there, and restart the unit, as the vinegar needs to get flushed by the condensate.
Your tray is designed to catch any leakage, and should drain to the outside. Look for your drain line and clear it. Tray drains generally plug at the ends, and not usually in the middle. You can clean the pan drain with a piece of stiff wire. I like to use electrical solid core wire, #12. Pass it dowh the drain from the pan, and back up the drain from the outside. Chase it with water. Usually the pluggage is either insulation, or dirt dobbers.
Best wishes and regards, W/D
Aug 17, 2009 | Heating & Cooling
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
