Question about Alpine Type-R SWR-1242D Car Subwoofer
Help on 1 amp and 1 alpine srw-124d
Hey guys/gals i'm a new-b to this stuff . my swr-1242d has 2 4ohm connections on it ...something like this ( - 4ohm + - 4ohm +)......now my question is where do i connect (1) - wire and (1) + wire?
example #1. (-) 4ohm (+) - 4ohm +
example#2. (-) 4ohm + - 4ohm (+)
example#3. - 4ohm (+) (-) 4ohm +
the simbol ( ) in examples 1 through 3 represent where?.... i should place the speaker wire ..please help ..thanks
  • 1 more comment
  • 213mike Jun 08, 2008
    i'm trying to connect my alpine swr1242d 12" subwoofer in a sealed box....but i dont know where to connect the red + wire and the black - wire...on the woofer ..for it has 2 4ohm connections to it....please see above examples...thanks
  • JEFFSANDERS2 May 11, 2010
    i just got the alpine SWR-1242D dual ported box
    now im trying to bridge it. But it's different from the audiobahn subs
    instead of two channels each side of the subwoofer
    on this there is 4 channels on each side of the subwoofer
    ?How would you bridge this?
    diagram would be great
    please email at JEFFSANDERS24@YAHOO.COM
  • Christophe Thompson
    Christophe Thompson May 11, 2010
    what are you trying to do and how many are you trying to do it with and is this with amp or without amp need a little more info so we know that were on the same wave length
  • 28 Answers
You have dual 4-ohm coils. 2 coils per speaker.using one speaker, if you take and run the postive from one coil and connect it to the negative of the other coil, then take a wire from your bridge channel on your amp and connect the positive to the the remaining positive on the one coil and connect the negative to the remaining negative on the other coil you will create a 8ohm load on the amp in bridged mode.
now this is the important part. The bigger the load on the amp the greater the wattage output to the speakers. This sucks the wattage out of the amp. Careful not to overload you amp. The setup above is safe for any amp. The following is for 2ohm stable amps only. The lower the ohm value 2, 4, 8 and so on, the greater the load on the amp.
connect the positive of one coil to the positive of the other. connect the negative of one coil to the other negative of the other coil. then take a wire from your bridge channel on your amp and connect the positive to the the positive on one coil and connect the negative to the negative on the same coil and you will create a 2ohm load on the amp in bridged mode.
Series = add the two ohm value
parallel= halve the ohm value
you can play with series and parallel together using more than one speaker setup.
Posted on Dec 10, 2008
I have a 12" d4 type r 1000 rms and a alpine 1000 amp speaker sounds great but smells like something is burning, my amp never over heats or shuts down but the smell is still coming from the sub?
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Apr 28, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
I dont how to run the wire on the back of my alpine type r 1242d
you can connect speakers up any way around ,if its one speaker with 4 connections then these extra 2 terminals are often for a continue through to the next speaker along the line ,.just use a small 9v battery and then connect to two terminals to find a bleep as you touch two of the terminals then you know where to put your wires
Nov 12, 2011 | Alpine Type-R SWR-1242D Car Subwoofer
What is the best box for 2 ALPINE SWR-1242D 12"SUBWOOFERS TYPE-R NEW SUB WOOFERS
Ported and tuned to around 37-40 hertz. After all displacement the box should be in the 2.2 cubic foot for sub and you will be very impressed. Build it yourself for optimum sound and output.
May 23, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
Alpine 7190ET Manual
Enter Alpine car audio in your search engine and go to alpines home page and then click on support then enter in the product # SWR-1242D and it will pull up the manual.
Mar 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
SWR-1242D wired at 4ohms
Hi!
Having to much power for a subwoofer is a veeeery good thing, it will provide a lot of control and quality sound to your sub.
But this sub is a dual voice coil at 2 x 4ohm so if you want to hook it up at 4 ohm u need a 2 channel amplifier running mono mode.
i dont recomend that you hook up in 4 ohm, its better to take some time adjusting the levels on the amp and the headunit.
This system has the potential to create a realy good bass sound if u tune it the right way.
Feb 10, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Wires
Hi Gott Mudd,
I can relate to feeling it in the bones. You got the stuff to do it.  You should try the Alpine MP3 head units with bass boost, those are bad to the bone.
Wiring:
Amp to Speaker I like to use the code VC for Voice coil, and AO for Amplifier output.  Also + for positive.  If I say VC1-, I am referring to the first connector starting left to right on the Alpine Sub. Now I have not seen a Kicker KX1200.1 amplifier.  All I see are MRA, MRP, or PDX prefix on the part numbers. So take what I am saying as a guess. You may want to revisit looking at the model of the amp to be sure your giving the right information.
We are going for  2 Ohms. Paralleling the two subs, not the voice coils. The voice coils will be series.  Bridge the amp if necessary to get mono channel. only using AO+ and AO- for output.
AO+ to Sub1VC1+
AO+ to Sub2VC1+
Sub1VC1- to Sub1VC2+
Sub2VC1- to Sub2VC2+
AO- to Sub1VC2-
AO- to Sub2VC2-
Set your Crossover to LPF
Adjust the bass gain down to lowest until you test.
Set the Frequencies to midrange between 40 and 100hz
Your box can be ported or not. It depends on the space your have.  If you do not have much room, go Enclosed and build a box that the inside space is less than 1 cubic foot.  Make sure you give barely  enough clearance for the speaker to fit.  If you have room, Go with a box and vent it with a 3 inch Vent tube 10 inches long.
Oct 15, 2007 | Alpine Type-R SWR-1242D Car Subwoofer
Alpine Type-R SWR-1242D Car Subwoofer Logo
229 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
