Question about Canon FAX-JX200
Auto print off
I can't receive a fax.
  • saoirsegodeo Jul 09, 2008
    Same thing here! The turning on and off is not working, plenty of paper and new cartridge inserted and still that bl**dy "auto print off" is being displayed! Please ... someone help me!!!!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Most often, Auto Print Off is activated by pressing the On/Off button, and documents are then stored in memory. Disable this function by pressing the On/Off button again.
The fax will also turn off Auto Print when the machine runs out of ink or paper, in which case, you should replace the ink cartridge or supply more paper. This situation usually results in display of the message Rec'd in Memory as well, and the unit will receive up to 30 transmissions or 60 pages maximum.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
Posted on Jul 02, 2008
I have a fax-jx200 it shows ;auto print off . so there are faxes in memery how do i get to turn off auto print.
Press [ON/OFF] to select <auto print off>
The fax starts receiving documents to the memory
To cancel press [ON/OFF] again.
Oct 20, 2011 | Canon FAX-JX200
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
Our Canon JX200 fax machine will send faxes but not receive faxes
Normaly it is the auto print off setting that is set to off,press the on/off button once less than a second then it will switch to auto print on.All the faxes in memory will be printed out.
Nov 30, 2009 | Canon FAX-JX200
Our phone/fax will send faxes but not receive them. Is there something simple that we are not doing?
Normally the fax is set for auto print off,set it to auto print on by pressing the on/off button once less than asecond,it will switch between auto print on and off.
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Incoming fax goes to memory and display panel Auto Print Off
If you press the on /off button once the machine will switch to auto print on,if you keep the on/off button in the machine will switch on or off.
Apr 08, 2009 | Canon FAX-JX200
I have a canon fax jx500
Turn auto print on by pressing the on/off button once.If you hold down the on/off button the macine switches off,if you press it once it switch beteen auto print on or off.At first I was also confused by this setting.
Feb 12, 2009 | Canon FAX-JX200
Receive faxes
Scroll through the menus.
You need to set your machine to AUTO MAGNIFICATION or AUTO REDUCTION
Oct 28, 2008 | Brother IntelliFAX 2800 Laser Fax
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon FAX-JX200 Logo
125 people viewed this question
old marine
old marine
