Water leak my ac has been clean recently now i have water driping, the drain line is clean,the pan is clean but the insulation near the pan gets soak wet and it leaks. coul some one help me.
  • pancho villa Jun 07, 2008
    the coil is clean, the drain pan is clean there is no leak in the drain pan because i turn the elbow and fillit out with water to make sure there is no leaks.
    Genius:
  • 3,422 Answers
HI,
Please CLICK HERE for some very useful info.
This is a very common problem that is easily solved. The way your air conditioner dries your house is by removing moisture. That moisture must go some where. The moisture is removed by condensing it on the cold refrigeration coils and letting it run down a drain pan.
The problem is that dirt and crud will stop up the drain line and clog the pan. This will eventually happen to every system out there give it enough time.
While this problem makes a terrible mess and seems like to end of your system it is really quite easy to fix. Most system simply use a 3/4 inch PVC pipe to drain the water to a floor drain or sink. when (not if) this drain clogs the drain pan over flows (especially when the fan stops) and you have a mess.
Fixing this problem is rather easy. Simply take a wet dry vacuum and **** the drain line clean, 9 times out of 10 this will fix it and that is the last of this problem you will have for a few years. If the drain pan is really dirty then you will have to take the covers off the unit and vacuum it out. In extreme cases you may have to use compressed air, nitrogen or CO2 to blow out the drain line (expect a big mess at the other end).If you don't have either avaliable you can use the Garden hose to flush the line backwards (expect an even bigger mess on the other end)
In rare cases you may actually have a hole in the coil drain pan in which case the coil or the pan will have to be replaced especially if it is steel (but this is rare). In other rare cases we have had situations where grease or oil fumes from the furnace have condensed on the coil and caused the water to fall off the coil. When this happens you must clean the coil with soap or some solvent.
If the coil is totally stopped up the back pressure from the fan/blower can force the water out of the pan by undermining the bottom of the coil. When the coil is this dirty the coil usually needs to be replaced. You will also notice little or no air flow.
In most cases these condensate leaks are a do it yourself repair. Only if you must take the unit apart and can't, do you really need to call for help.Here is a device that will allow you to clean the drain with ease and
not have to take it apart each time.
Goodluck,
Please don't forget to rate or accept the solution
Posted on Jun 07, 2008
    Sergeant:
  • 284 Answers
Theres not much you can do the prevent condensation forming on the pipes of an AC(which is normal, the AC is probably forming alot of ICE (frost) and melting quite fast.
you could put the AC in and 3 degree angle pointing down so the water can travel in the direction you want it to flow.
That might make it work.
The drain pipe if its clean then you have the let the water accumilate ir you could make like a small funnel out of aluminum foil and place it where the water dripping, or try to cover the insulation with foil tape so the water does not hit it.
That might help also.
  • 407 Answers
An air conditioners primary job is to remove moisture from the room to give us a feeling of comfort. During this process they create a lot of water. How much, is dependent upon humidity in the air, size of the air conditioner, its operating efficiency, and whether it was properly installed.
  • krishna Singh
    krishna Singh Jun 07, 2008
    Water removed from the air during operation falls down the cooling coil and drops into the base. From here it follows channels or passages to the rear of air conditioner. Some of the water is lifted up by the fan blade and used to cool the heating coil, while most proceeds to the rear. Once at the rear it drops out of the base and onto the ground. That is, if everything is working perfectly.
    The reality of window air conditioners is that they can leak water. One that leaks can drive you crazy trying to find the cause of the problem. The following are a few suggestions of the most common reasons why water leakage occurs.
    Improperly installed.
    A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
    Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
    Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
    Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
    Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
    Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
  • krishna Singh
    best of luck
2005 buick lesabre AC hose plugged leaking water onto passenger floorboard. How do I fix this?
You need to find the drain pan line that comes through the firewall. Open the hood and search for the line on the passenger side firewall. The line is probably clogged from insects, animals, or other gunk. use a short piece of dowel or wire to unclog the line and allow the pan to drain to the outside of the vehicle.
Aug 30, 2014 | Cars & Trucks
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
My handler is leaking. The drip pan has a little water in it, I see a slow drip outside during operation. Near the blower water is coming out of one of the air ducts.
Hello, most likely you have a clogged condensate drain or a cracked or leaking condensate pan. First use a wet/dry vac on the outlet of the drain line, this will usually unclog the line. If the line appears to be clean then the pan will have to be replaced.
Sep 27, 2011 | Heating & Cooling
There is water leaking out from the bottom of my furnace. It leaks whenever the ac is running.
Hello, sounds like a clogged condensate line or a faulty condensate pump if the unit has one. Cleaning the drain line should fix the problem.
Jul 12, 2011 | Heating & Cooling
My PAC C110 air conditioner leaks a lot of water why?
Water leaking due to:
1. Non insulation of copper pipe lines.(Insulate with insulation material) 2. Dust blocked in drain pan. (Clean it) 3. Cooling coil and air filter blocked. (Clean it)4. Airlock in your drain line. (**** air from your drain line)
Dec 25, 2010 | DeLonghi Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Jan 16, 2010 | GE Quiet-Aire Ductless Split System Air...
We have RUUD AC, in second floor , that has a white pvc ope connected to condensate drain. other end of this pipe is inerted into large pipe neanr wall. looks a drain outlet. In the middle of this white...
Hello, W/D here.
There are a couple of things you need to check:
Look at where the drain connects to the A/C unit. There should be another pvc line right next to where the drain connects. This is the clean out/flush line, and is used for adding algeside to the tray internally, which thens go out the drain. Most importantly, there is a 1/8" hole between them, and usually, it's very hard to see. Make sure that this hole is open. If it is plugged, the condensate cannot drain from the unit while the unit is running and will create havoc with your drain system. The 'tee in the drain line is an air vent/vacuum breaker and can be used for a cleanout, but try the little vent hole trick first. Your drain line from the unit should be sloped to your house drain. If you do not have a clean out connection at your unit, then you can clean from the tee to the wall. Put one cup of white vinegar into the tee. It will work as well as bleach, without the corrosiveness of the bleach. If you have a cleanout on the unit, put the vinegar in there, and restart the unit, as the vinegar needs to get flushed by the condensate.
Your tray is designed to catch any leakage, and should drain to the outside. Look for your drain line and clear it. Tray drains generally plug at the ends, and not usually in the middle. You can clean the pan drain with a piece of stiff wire. I like to use electrical solid core wire, #12. Pass it dowh the drain from the pan, and back up the drain from the outside. Chase it with water. Usually the pluggage is either insulation, or dirt dobbers.
Best wishes and regards, W/D
Aug 17, 2009 | Heating & Cooling
04 trailblazer AC leaks
Rather than pay the dealer $350+ to fix this, I found the "L" shaped drain hose behind and interior to the front passenger tire (I let the car idle with the AC on and waited for a drip. On my back on groud I reached in and found the drain line and it came off i my hand and about 4 oz of water and some decayed matter floowed out. I reaced back in and found the hole to which the L line was attached. It was a rubber fitting on the end of a metal pipe. The fitting came off easily and then about 8 oz of water flowed out (carpet had been soaked for two days). I reattached the L drain line and noticed that inside the fitting was about 1/4 tsp of "mulch" - decayed leaves, pollen, etc. Reattacted the fitting and water now flows freely out the drain. And yes, its a very high humidity area - Houston, TX. And if you live anywhere near here you know about the intense yearly dispersion of Pine tree pollen. I thisnk that accelerates the blockage. Happen about every 2 years. (Third time for me. First two I let the dealer over charge me for this effort. BE SAFE WORKING UNDER YOUR CAR!
Jun 22, 2009 | 2004 Chevrolet TrailBlazer
Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Jan 25, 2008 | Heating & Cooling
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
