Heavy white lines accross the screen
The monitor has heavy horizontal white lines across the screen. The desktop behind the lines shows up in double. The problem would occur occasionally and currently it has this condition all the time with either the VGA or DVI cable. I've tried different cables, computers, video cards and nothing seems to cure the problem. The monitors is 5 years old. What should I do? my monitor displays heavy multi colored lines in the screen..i tried it on the other pc and it worked out normally..maybe the problem is inside my cpu(system case)..the multi colored lines is visible but the desktop and pictures are also visible..
  • helen fegan Dec 20, 2008
    coloured lines accross my desk top can you help
  • Arcadian Duran
    Arcadian Duran May 11, 2010
    check for blown capacitors on video card or mother board
    also check the memory of the computer.
    the RAM could have gone bad.
  • 611 Answers
Change the ram and viedo card agian
Posted on Jun 07, 2008
Ten year old emerson 27" flat-screen tv has multiple thin white horizontal lines and has audio
Backlight CCFL lamps fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 30, 2014 | Emerson Televison & Video
Black screen with flashing horizontal lines
it can be the fibre or someone pressed the screen on the topside or plced something heavy on it
Apr 14, 2017 | Compaq Presario C700 Series Laptop...
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
Horizontal line appearing on desktop
The fault looks like white lines horizontally along the screen. These are the retrace lines that become visible due to absence of proper screen/grid voltage. You will need to open the monitor only if you are familiar with power electronics, a bit of experince is important as the stages are delicate and contains high voltage. If not take help, check for faulty capacitor or low value of resistors in the screen/grid sections of the crt. Couple across parallel to the suspected capacitor to confirm and change. Use a meter to see the voltage across faulty resistors. In some cases reducing the screen potentiometer ( onthe Line output transformer)can solve the faulty. Hope you try. Good day
Aug 03, 2010 | Computers & Internet
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Horizontal ghost lines across screen
Seems that it is an issue with your video card, Please update Driver for Video card and it that does not help, it is the time to replace the Video card.
You can get your driver from support.dell.com and please enter your service tag to download the driver
May 25, 2009 | Dell M781S Monitor
LG F700P monitor black out on top half, horizontal white line
Sounds like your monitor or graphics card may be going bad.
Dec 07, 2008 | Computers & Internet
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Replace it, it is going bad. I could tell you what would cause this such as bad driver IC etc. but bottom line is its five years old, you got your moneys worth out of it so bite the bullet and get a new one.
Feb 11, 2008 | Envision EN 9110 19" Flat Panel LCD...
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
