HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
Posted on Oct 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HP 8500 wireless has been setup properly using wireless network. but cannot be setup with printing using wireless on my macbook and macbook pro. how can i do the setup for mac using wireless ?
broris holt
Level 1:
  • Contributor 20 Answers
  • Posted on Apr 27, 2020
broris holt
Contributor
Level 1:
Answers
20
Questions
0
Helped
20071
Points
91
Hi There,
If you are using HP Printer and you are unfamiliar with Printer Setup process then you can read this blog maybe it could help you and make you familiar with the setup process. https://printererrorstate.com/blog/how-to-hp-wireless-printer-setup/
Level 3:
  • HP Master 7,733 Answers
  • Posted on Oct 23, 2010
HP Master
Level 3:
Answers
7733
Questions
0
Helped
1864853
Points
21487
Inkjet 3 failed
Forget it HP.. has now found a way to recongnize when a cartridge has been jail broken and will not allow the printer to print. The cartridges have circuits imbedded in them so the printer can recognize the originals from the knock offs. Many are outdone at HP, as they are now dictating what product you can use in the printer. That is why the printers are so cheap. They make up for it in ink.
1helpful
2answers
I have a HP officejet 8500 wirelsss. It had worked finme since we nought it abiout 4 months ago. Now we can't print from any PC...says "disconnected. We did have a TWC technicina in to replace the...
If they installed a Modem/Access point that the computer talks to via wireless than this has become the new "hub"You may need to tell the printer the new settings so it knows to go through this "hub" 1. Press Setup 2. Scroll Down to network, press OK 3 Scroll to wireless network setup (could also be named Automatic Wireless Setup or Wireless Setup Wizard). Press OK 4. Highlight the Wireless Modems name, it will ask you for a password that the TWC man advised you, or you have set up. 5. It should connect to this and hopefully resolve your printing issue.
I hope this helps, if so please rate this response below Thank You for supporting the FixYa Community Regards GM
When I print avery label 74520 on my HP Office Jet Pro 8500, it prints too far to the left on the paper label.
You have to setup printer details, not to sure of programme, if word try looking under mailings/envelopes. There you have the choice to alter the details of the item you wish to use as a template. Good luck.
Peter.
I am using a mac book pro attempting to print to an HP 8500 model A909A that is connect via airport to the network. I receive the error message "can not read printer head. short read." I have...
Have you setup the the printer to find for wireless and you also then must setup the "Mac" for wireless.
The printer will then seek wireless products and log in. Its fairly simple, I had a similar problem the mistake was setting up the printer to seek other wireless products
I have a HP Officejet Pro 8500 printer, Model No. A909a. Is it a wireless printer? Can I connect my laptop to the printer with an ethernet cable?
Yes to both your questions!
If your laptop has wireless you need not use the cable if you connect via wireless to the internet router, you can use printer wireless to , you just need to seup the laptop to use the facilty.
You setup the printer through "Tools" look for Network and "Wireles Setup Wizard"
Same applies with the laptop through control panel.
OfficeJet Pro L7780 controls non-responsive
There is conflict between the Printer and Router you are using. The Router is freezing the printer connectivity to the network due to the Wireless radio ON option in the printer
There is a firmware update for your printer, Let your printer be connected thru USB and from this link, download and install the update for your printer and later try setting it up wireless, it should work.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62339-2&lc=en&dlc=en&cc=us&os=2093&product=2512010&sw_lang=
If this step fails, the other step is, to Enter the printer IP Address manually in the printer Network menu from SEtup Option and later run the wireless setup wizard to connect it to the network.
1helpful
No connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Wireless printing to HP officejet Pro 8500 Wireless Printer
Open "Control Panel".
Open "Printers".
Click to select the printer.
Click the "offline/online" button, to mark it as "online".
Print.
HP OfficeJet Pro 8500 A909 does not print wirelessly from my MacBook Pro with OS 10.6.2 (Snow Leopard). How can I get it to print wirelessly?
i cant print what happening. Its telling me to load paper but i have paper in slot. This started happening after a paper jam.
k24674
Grand Canyon Tech
Grand Canyon Tech
