Question about Dryers
Cdt00 the dryer wiil start to turn with no stuff in it but when clothes are added the drum struggles to turn
    Scholar:
  • 110 Answers
Bad motor
Posted on Jun 07, 2008
Why doesn't drum turn when the start button is pushed?
try turning the drum by hand while on dry cycle> just tape shut or hold door switch in by hand then have someone turn the drum? see if it starts? if so ur motor windings may be bad ad not pushing enough power to run machine, also check the thermal fuse and other thermostats as u may have shorted them somehow? lastly check the belt and tensioner as the motor switch may have switched off if there was a problem with the belt
Jun 03, 2014 | Samsung Dryers
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
My cabrio dryer wed7600xwo is no longer drying right, I have to run loads 3 times to get them dry. What could the problem be?
This dryer has 2 belts. A smaller belt operates the blower. The nut tends to back out and the small belt falls off. Here is the result:
Bravos dryer innards of a failed blower belt
Look around on my foggy site for your service manual. Let me know
Feb 22, 2013 | Whirlpool Cabrio WED7600XW Electric Dryer
Clothes get caught between the drum and the front of the inside nonmovable part of the dryer and we are getting snags of the clothing inside and ruining the clothes
there is suppose to be a felt type piece that goes on the drum to full that gap it may have fell off . its a struggle to put on unless the drum is accessible. you can pop the top of the machine off to get better access.
Aug 23, 2009 | GE DBXR463EDWW Electric Dryer
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Jun 07, 2009 | Dryers
Dryer won't turn
The problem is likely a slipping dryer belt. The belt tensioner is not working or the belt needs replacing.
Apr 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Hotpoint condenser dryer CDT00
how to connect the dryer belt to the motor is there is two pullys.
Mar 30, 2008 | Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
