TV doesnt Come On
When you turn on the TV on, the green in front of the tv comes on there is a clicking three to four times in the back of the tv. A red light comes on in front of the tv and flashes 5 times, tv never comes on, picture sound nothing.
  • yrush Jun 07, 2008
    I dont know if it matters but it is a Plasma TV Philips model 42PF7320A/37
    Philps 42pf7320a/37 Plasma TV.
    Genius:
  • 1,011 Answers
Dear sir/madam,
It is almost certain that the power supply unit is in what is termed Hiccup mode which is simply the power supply shutting down when a fault is sensed , of course when the set is switched off the fault can not be seen so the set switches on again whereupon the fault is sensed again so the set switches off , ad infinitum , hence the flashing power light ! Usual cause is short cct line out transistor or transformer .
Second, is the tv cabinet or table where the tv is placed moving?if so. check out for loose solders especially the power supply section(regulators),and power aux supplys. if the symptom still exist.a certified tv technician is needed.
Thanks
Good Luck
"Don't forget to rate the solution"
Posted on Jun 07, 2008
    Genius:
  • 2,035 Answers
This could the problem with TV board please unplug tv power and leave it foe 30 minutes if it still blights you need replace the board or the color IC as over the time the dust is accumulated inside tv and you need to get it service from service center the cost from $50 to high of $ 250.................
Good luck....................
  • Anand Kumar
    Anand Kumar Jun 07, 2008
    TV light :
    When it shuts off. Try doing what's called a self-diagnostic test.
    As soon as the television shuts try these steps.
    Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
    activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
    has occured since the last Initalization.
    Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
    ? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
    ? The flashing then pauses for approximately 1/2 second.
    ? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
    ? The Error Code is repeated a total of 5 times.
    Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
    times.
    The Error Code designations indicating a malfunction, or no malfunction, are listed below:
    Self Diagnosic Code Description
    1 - 2 = no error detected
    2 - 1 = X-ray protect (high voltage or beam current)
    2 - 2 = Short protect (short protect monitors low voltage supplies)
    2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
    2 - 4 = Vertical protect (usually loss of vertical from the source).
    Genius:
  • 3,422 Answers
HI,
Can you please give the make and the model no.
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv will come on but shuts itself back off
Sounds like it just needs a new lamp.
The way to tell is the lights in front:
green blinking as TV reboots = bad lamp
red three blinks = door switch
red four blinks = bad fan
6 or 9 blinks = bad thermal fuse
Dec 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
42PF7320A/37
Hi again,
Did you try connecting the TV into a different power outlet?
Jun 07, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
