Question about Frigidaire Refrigerators
Fridge is not cooling at all. Just replaced the defrost heater because ice all on back of freezer.
    Scholar:
  • 110 Answers
There are 3 components in the defrost circuit line def. heater, def. t-stat., and def. timer / adaptive def. control. with that being said frigidiare rf are more than likely to have a bad def. t-stat on models made before 2003 and the adc fails on model made after that time
Posted on Jun 07, 2008
  • 87 Answers
SOURCE: fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Posted on Sep 06, 2007
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
  • 111 Answers
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
Posted on Jun 17, 2009
mgprice
  • 744 Answers
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Posted on Jun 23, 2009
localwonder
  • 6784 Answers
SOURCE: I HAVE A MAYTAG MZD2766GE,
HI. There are two causes here, in this situation. The most common will be a faulty defrost timer, or adaptive defrost control board. The defrost mechanism will vary form unit to unit. Most newer units will be equipped with an defrost control board. This will be located in the control housing, just above the heat shield, in the upper right had side. Older models will have a standard defrost timer mechanism. If this device fails, the evaporator heater Assembly will not receive the command to defrost the coil, on time. The easiest way to isolate the cause, will be to test the heater element. If the element is functional, the defrost timer/board, will be the culprit.
Defrost heater assembly test procedure:
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice-maker and the inside rear or bottom panel of the freezer, to access.
The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky, so try not to force it, if possible. If you decide to remove it, you do so at your own risk. it will break, if forced. Warm it first with a warm towel, or hair dryer, set to low heat.
There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely faulty, and should be replaced.
Posted on Sep 06, 2010
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
Jul 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
Ice forming in the top freezer, leaks in the bottom refrigerator section
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
May 27, 2011 | Kenmore 18.2 cu. ft. Top Freezer...
I have an amana fridge model # arb190rcw.nothing remains frozen in the freezer.and i have noticed ice on the back wall of the freezer compartment
Your cooling coils have frosted so much that there is ice forming allover the cooling coils and preventing the actual cooling inthe fridge. First of all shut off the fridge for about 10 hours and wait for all the ice to defrost. Clean up your fridge well and then check inside of the freezer compartment for break in wiring, failure of the heater or the thermostat. Now put the fridge on and see if the cooling comes back.If the set works ok then dont worry till you experience the same fault coming back. In this case your auto defrost timer could be faulty as it is not doing the 8 hours cycle defrosting. Check this out test and replace . Get help if you are not familiar. good day
Jul 31, 2010 | Amana ARB190RCW Bottom Freezer...
Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Oct 28, 2009 | Refrigerators
Fresh food compartment not cooling freezer is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 27, 2009 | Fisher and Paykel E522BRX Bottom Freezer...
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
The freezer is cooling but the refrigerator is not cooling
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
Sep 03, 2009 | Refrigerators
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Freezer works fine but fridge has lost its temperature.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 02, 2009 | Refrigerators
Fridge/freezer cooling inefficiently
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
74 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
