Question about Microsoft Xbox 360 Console
Reset to 480i with out seing dashboard.
I previously played my xbox on a Flat screen HDTV, and had set it to 1080i. I had to go work out of state and braught only my xbox and not the TV. Now I am trying to use it on a hotel room tv, as you may have guessed I can hear sound but no picture. Is there a way to reset the xbox to 480i, just on the console? If not can some one tell me the trick to changing it back to 480i using just the sound i.e. I know it's three clicks to the right to get to the system blade then one A click to get to console settings and so on but I need to know the whole "CODE" left, right, A, B....ect.... to get from 1080i back to 480i. Please any help would be good, I already spent $75 on a RCA - Coax converter box and $40 on a new controller (because I forgot my other ones.
Thanx,
Cody
    Novelist:
    Champion:
  • 210 Answers
Here you go:
1. Remove any discs from the disc tray.
2. Turn the console off.
3. Turn the console on.
Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this. The player 1 controller will have the upper-left quadrant light illuminated.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
5. The Xbox Dashboard resets the display settings to the default settings, and then automatically restarts the console .
Happy Gaming....!
Posted on Jun 07, 2008
I have a sceptre model x9g-naga v flat screen monitor that I am trying to connect my x box 360 to. It allows me to play games, but when I put in a movie, it says, secure hdcp link not found. I was told...
A simple work around that could be able to fix it is by turning on the xbox, waiting until the screen showed the logo and the error message "secure hdcp link not found" then unplugging the hdmi cable from the back of the xbox and plugging it back in. Of course having to do this each time you wanted to turn on your Xbox would be annoying. (I have not tested this using VGA cable hookup though)
If you are asking how to change your Xbox to 480i then you will need simply use the red, yellow, and white cable as it defaults to 480i. (not possible with your monitor I don't think)
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Console Settings.
  3. Select Display.
  4. Select HDTV Settings.
  5. Select the appropriate screen resolution for your TV or monitor. 480p,720p,1080i,1080p, 1024x768, 1280x1024.
I am assuming from your TV that you are using VGA? With VGA then your system is going to automatically choose the best display for your monitor. You can go into the display settings as described above to adjust your display settings.
Hope this helps.
Aug 02, 2011 | Microsoft Video Game Consoles & Games
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
http://www.hdtvoice.com/voice/showthread.php?t=16973
http://www.hdtvoice.com/voice/showthread.php?t=8721
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See:
http://www.hdtvoice.com/voice/showthread.php?t=1044 and
http://www.hdtvoice.com/voice/showthread.php?t=1052
Sharp LC=32D43U display capabilities
is the switch set to hdtv on the cables... and are the display settings in the dashboard set to hd
Dec 26, 2007 | Sharp AQUOS LC-32D43U 32 in. LCD...
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Getting my Sony TV to operate in 1080i.
Asumming you have set the Xbox at 1080i in the video settings and you have used all the four component lead ends, (apart from the yellow video end, as you won't need this) it should work.
Jan 11, 2007 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Xbox Dashboard on high definition TV
With the latest update to the Xbox Dashboard available from Xbox Live®, you can change the default display mode of the Xbox Dashboard from 480i to 480p. Connect your console to the component inputs of a 480p-capable TV using an Xbox High Definition AV Pack toview the Xbox Dashboard in high definition. To get the latest Xbox Dashboard Using a Broadband connection and the Ethernet connector on the back of the console, connect your Xbox to the Xbox Live servers. When you do so, the latest version of Xbox Live, including the Xbox Dashboard, automatically downloads. You do not need to subscribe to Xbox Live for this update to automatically download to your Xbox. But if you don't have an Xbox Live account, get one! To set the Xbox Dashboard to 480p Connect your Xbox console to the component inputs of a TV that supports 480p with an Xbox High Definition AV Pack. Start the Xbox console without a disc in the tray to run the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Livearea rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twiceto return to the Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select Yes to confirm that your TV supports 480p. Pull and hold both the left and right triggers. While holding the triggers, click (press in) the left and right thumbsticks. After a brief blank screen, the Xbox Dashboard will display in 480p. If you want to return to 480i, repeat the controller combination in step 7, or switch your Xbox High Definition AV Pack with another type of AV pack. Note The opening Xbox animation does not display in 480p, only 480i. To resetthe Xbox Dashboard to 480i Start the Xbox console without a disc in the tray torun the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Live area rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twice to return tothe Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select No to indicate that your TV does not support 480p to reset your Xbox Dashboard to 480i. If your screen appears blank or scrambled If your Xbox Dashboard does not display correctly while in 480p, it might be difficult to see the menus to reset your display to 480i. Connect your Xbox High Definition AV Pack?s green color-coded video output jack (the one marked with the letter Y) to the composite video input of your TV. Note The composite input on a TV is normally color-coded with yellow. Proceed to reset your display to 480i as described above
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
622 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
