Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic red and blue picute
We had a normal pictue then all of a sudden the picture went into 3d mode and we can't get the convergence to work
  • ghostflames Jul 03, 2008
    turn on tv and has red and blue ghosts,kinda three d like
  • Panasonic Master
  • 8,617 Answers
You need to replace both the convergence Ics they are STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions. heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 07, 2008
Mitsubishi tv ws 65315 red screen
if the reds and blues look 3d etc it is a convergence problem. see attached photos of a typical convergence problem.
Apr 28, 2012 | Mitsubishi WS-65315 65" Rear Projection...
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | RCA HD52W59 HDTV Projection Television
Sony Grand Wega KF-E50A10 looks like it is 3D and we can't adjust the convergence through the screen settings, what should we look at next? Red is the color not lined up, blue and green seem fine.
Most likely if you cant adjust the convergence then the convergence IC's are in need of replacement. Does the picute look like the one below? if so then these chips need replaced. dcramer531_120.jpgdcramer531_121.jpg
Jul 05, 2011 | Sony Televison & Video
I have mitsubishi vs-50800 i was watching a movie and the screen just all of a sudden went blury and the color is all mixed up i went to the convergence menu and it wont allow me to move the colors left or...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | Mitsubishi VS-50800 50" Rear Projection...
I have a panosonic TX-47PT1. No problem since new. 3 days ago the convergance went. The colours (mainly red ) have slightly seperated and become a horizontal wave. I have read the forums and it seems there...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 02, 2011 | Panasonic PT-51HX43 51" Rear Projection...
Hello
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Jan 03, 2010 | RCA R61WH76 61" HDTV
The picture looks 3D
  • Screen looks 3D
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Blue/yellow shadows
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Apr 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
Panasonic blue convergence problem
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
Sep 14, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
