Question about Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher
Won't fill with water
I have replaced the blue water valve with a brand new one and still won't let in any water. Clicking can be heard, and all the lights work like it is filling.
Thank you. Bob.Christian@Minarik.com
    Sergeant:
    Champion:
  • 338 Answers
Sounds like you float switch may not be enguaging
Posted on Nov 25, 2008
How do i fix e5 on the dishwasher
Three common causes.
  1. Defective solenoid water inlet valve
  2. Plugged water inlet filter
  3. Defective stop valve located where the inlet hose connects to the water line.
Problem 1 usually no water will enter. It usually works or not.
Problem 2 and 3 the situation is the tub begins not to fill and over time the filter closes completely or the stop valve plugs completely.
If you open the door after the fill cycle and you have not heard the unit fill it is most likely the fill solenoid. Partially filled need to look at the stop valve. The rubber washer of the valve deteriorates and loosens relocating over the hole plugging the water from going through. When you try to shut off the valve it in most cases will not close water tight. You can replace the stem and washer if you can find the same hardware type.
The solenoid replacement can usually be axcessed from the front but requires a skilled technican.
26051739-3tozjaopshvuyndb2zxhmboi-4-0.jpg Solenoid valve below
26051739-3tozjaopshvuyndb2zxhmboi-4-2.jpg Hope this helps?
Jan 13, 2016 | Dishwashers
Hello & Welcome to FixYa
Dishwasher not filling problem is caused by clogged inlet valve, first try to clean the inlet valve and the water line coming to the inlet valve. If the issue returns replacing the water inlet valve is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 20, 2011 | Baumatic 18 in. BFD46 Free-standing...
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Hello my tricity bendix dishwasher won't take in water, it will pump it out and when I turned water off at the mains and disconnected the water pipe and put it in a bucket turned mains back on the...
Hi
Daniel
Aug 11, 2011 | Tricity Bendix 24 in. DH102 Free-standing...
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher will not fill have changed the inlet valve but still not filling.
Hi
Daniel
Jul 20, 2011 | Bosch Dishwashers
My plumber just installed a new water supply line for my dishwasher. Now the pump comes on but no water fills up in the machine. If I fill the bottom of the unit with water, it works just fine. Even though...
You don't know how many times I've heard and found the shutoff valve off or partly turned off. Water entering DW is from line pressure not pumping. Items to suspect (again) the water supply valve (would'nt be the first time a new valve is bad). The supply valve (3374621) at the Dw, the float safety switch (normally at front left side,)...remove lower rack, lift float housing up and down. You should hear a click both ways and the housing should be free. Is the Dw fill valve getting control signal from timer. Should be 120v for about 60 sec.
Ric
Mar 10, 2010 | Whirlpool 24 in. DU915QW Built-in...
Will not fill with water
The problem is most likely the water inlet valve. This is a solenoid that opens when there is power to it. It is a common problem on dishwashers and washing machines.
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
May 27, 2009 | Frigidaire PLDB998A Built-in Dishwasher
Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher Logo
71 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
