Question about SanDisk Sansa Clip MP3 Player
Sandisk clip I need a replacement clip for my 1 gig clip. Just the clip that snaps noto the back of the playr.
  • 8,596 Answers
Call Sandisk at 1-866-726-3475, or get a broken player off of eBay for low cost and just swap out clips. Now, there is a plastic piece that holds the clip into place - that plastic piece didn't break off, did it? If so, you must replace the entire player.
Posted on Jun 07, 2008
How do you install trunk struts on a 1998 volvo S70? The problem is with the end behind the seat?
My procedure (after spending 2 hours finding nothing but dead ends and 20 minutes after I figured out the procedure...). Also, found that having a second person is key to making things go smoother!
1. Purchase a pair of quality struts with specifications for trunks with or without a spoiler on it. Trunks with a spoiler requires a heavier, beefier strut. Save yourself a headache and replace both struts while you are at it, no need to face this task 6 months later. Fluid leaking out of struts are a sure indication that you need new ones!
2. Remove and save the old strut to compare it to the new struts you purchased. There are two accesses you'll need to position yourself in: 1. from the trunk and 2. from the back seat into a tight wheel well cavity that you can hardly get your hand into.
3. From the back seat, pull down the backrest side cushion near the door on each side to access the cavity that has the rod end with the plastic clip inside it. The cushion pulls out when grabbing the top and pulling towards you. No need to manhandle this cushion and you only want to pull the top off and slant it sideways in order to get your hand inside this small cavity through the access hole.
4. Note that the plastic 'clip' end of the strut is attached to a permanent welded pin located inside the cavity. Using flat head screw driver, pry plastic clip off of welded pin inside the cavity.
5. On trunk side of the strut, use a small flathead screw driver and insert under retaining clip to release the old strut from the permanent bulbous pin welded to the body. Note: You can check out your new strut and you'll see how the clip needs to be 'pried' off slightly to open the aperture where the bulbous/rounded pin head goes into and it would snap on.
6. Now compare your old and new struts. Look closely at the two ends and compare the sizes. Particularly compare the 'plastic' "C" end clip at the end of the strut rod that has to 'snap' over the pin that is welded inside the cavity. Getting the plastic "C" end clip off is a ...'snap' but getting this back on and 'snap' in place is a potential project.
7. For me, after comparing the old and the new ends, I had to file down the new plastic "C" end clip so it would look almost identical in size to the original one I took off and would be able to 'snap' back on over the welded clip inside the cavity. The other side of the strut that is installed from the trunk was just fine so I didn't have to do anything there.
8. When trying to 'snap' the "C" end clip over the pin inside the cavity, I found that I couldn't get enough downward pressure on it to 'snap' it in place. So, I took someone's suggestion on the web to loop a 3/8" small rope over the end of the clip inside the cavity, draped the two ends of the rope outside the opening to the cavity and exerted 'downward' pressure on the rope pulling the clip against the pin which forced the "C" clip to 'snap' into place over the welded pin!! Slight filing (not too much) will get the end just right to snap over the pin and it's plastic which files off in seconds. Little at a time or else you find you just destroyed your strut! Note: prior to the rope trick, I tried every tool known to man to snap this clip in place inside the small cavity!!! For my big hands, there is just not enough room to get your hand in there to move around, never mind getting a tool in there as well! Once you look at this ridiculous setup, you'll know exactly what I mean!
9. Now the easy part. From the trunk, prepare the other end of the strut to install over the bulbous end of the permanent pin welded to the body by prying the retaining clip as previously mentioned. You'll see as you pry off the clip (but do NOT remove it completely) the opening on this end of the strut will permit it to slide easily over the pin. Best to have one person there to move the trunk up or down to align the pin to the end of the strut to line it up and slide it on.
10. Bingo - slide it on, make sure you press the retaining clip back in place so it grabs the bulbous end of the pin and you're done! Like I said I spent 2 hours fiddling about and 20 minutes installing both struts once I got the filing of the end and rope trick down!
Key to this project: compare the ends you are trying to snap and slide on (adjust/shave if necessary), get access from the back seat by pulling back the side backrest cushion to access the cavity and the old 'rope' trick to get downward pressure to 'snap' on the darn "C" clip inside the cavity!!
Good luck - you can do it with only a screwdriver and piece of rope!
Nov 01, 2010 | 1998 Volvo S70
How do I get to the back tail light to replace it. I removed the cover where the light is, however I can not get to the light bulb itself.
Tail light replacement is not as hard as it seems.
Tools needed:flat head screwdriver and a deep 5/32 socket(a pair of pliers will work).
Step 1: open trunk and pull back truck liner at tail light.There is a small button clip on liner.Use screwdriver to pop up the center of button clip,pull clip out of hole.
Step 2:You will see a black wire attached to the body of car with 2 white clips.Use screwdriver to pop clips off of studs.
Step 3:Remove the nuts from the studs and pull tail light assembly straight back away from car.The outer side of the light just snaps in and out of place.
Step 4:Turn light socket counter clockwise 1/3 turn and pull out.
Step 5:Pull bad bulb straight out and replace.Reverse steps to reassemble.
Mar 22, 2010 | 2007 Nissan Sentra 2.0 SL Sedan
How to replace exterior door handle on the back passenger side. What tool is needed?
there are two rivets that you will have to drill out. on the inside of the door, there is a threaded clip that holds the linkage in, you will have to open it (it opens like a door, it may be a little stubborn, but it will open). then put your new handle on, and then the linkage back in, and snap the clip back in place. you will need one of the bigger pop rivet guns because the rivets are 1/4 ones. also, when you go to rivet the handle back on, tape some cardboard under the handle. that way if the rivet gun drops after it snaps off the rivet, it will not scratch the door. hope this helps you.
Oct 14, 2009 | 2000 Ford Explorer
How do i remove interior door panel & trim
Answer There is a small black plastic piece that surrounds your door handle. You MUST take that off, I find a small flat tip screw driver works best. The plastic cover that goes on the inside part of the door where your mirror is should be removed, makes it a lot easier to remove door trim: No screws on that part just grab from both sides and pull. 3 screws on bottom and 1 screw inside the armrest. The window crank, easiest way tried and true, shoestring, pull handle towards inside of car until you have enough room to fit the shoestring between crank and plastic washer. Give it a pull back and forth and it'll pop right off; clip should stick to shoestring as an added bonus.
Jun 01, 2009 | 1999 Daewoo Lanos
Interior trim panel removal instruction
Normal 0 . Disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
If you don't have power windows you will have to remove the manual window crank. It is held in place by a clip on the back side of the base. To remove the clip, you will need a small hook (kind of like a knitting needle). Put the hook in behind the base, and grab the clip and pull it off. To replace it, slide the clip back on the window crank, and snap it back on the door.
May 31, 2009 | 2003 Volkswagen Passat
How do I remove a 1995 buick park avenue drivers side door panel?
Normal 0 . First thing, disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
May 30, 2009 | 1995 Buick Park Avenue
How do I remove the front door panel to replace the mirror
Normal 0 Disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
May 25, 2009 | 1998 Buick LeSabre
The window keep sliding down. What should I check first. Do the window motor need to be replaced?
I have had two Roadmaster Wagons (we love 'em) with the same problem. The problem I found was only in a plastic clip that the actuator arms snaps into. I have not found an easy solution to replace, but it can be done. Take off the door panel and lower the window some (with help of a friend) so you can see the track at the bottom of the window. In that track there are plastic clips with a socket that a ball from the actuator arms snap into. You will probably see that one (or both of those) is broken. You need to slide out the old clip (you will need to bend out the indentation on the metal track so you can get it out) and slide in a new clip from a salvage yard. Now the hard part is pressing the ball from the actuator arm back into the socket of the new clip. I found I needed a special pair of pliers that opened wide enough without requiring the handle to open too far. After it is snapped back in, you should be ready to put the door panel back on and hit the road.
Apr 28, 2009 | Buick Roadmaster Cars & Trucks
Not working 1gb sansa clip
What does that mean - "music db" ? I put all of my music on my 1 Gig and it works great. I put all Harry Potters audio books on my 8 GIG and still have 1.5 gig left for music.
Feb 03, 2009 | SanDisk Sansa Clip MP3 Player
Rx tray full remove paper
That is an easy one.
Look into the area where the paper comes out. You have to look toward the upper rear area rear area. There is a white plastic flag, about 2 inches wide and 1 inch in height.
On each side of it you will see 2 areas where the shaft snaps into, that flag has popped out of those clips and is not seeing the sensor making the machine think there is a piece of paper in the output tray.
Reach in and gently maneuver that back into position and carefully snap it back into place.
That is an odd shaped actuator you can't see, but with some patience you can snap it back into place. Maybe also gently take a pair of needle nose pliers and slightly tighten those clips that it snaps into. I suggest that with a lot of concern so that you do not snap the plastic clips, they are part of the frame that if broken would be expensive to replace. Use your discretion as to whether they need to be tightened. If it snaps back in and feels solid DO NOT try to tighten them please.
Jan 01, 2008 | Xerox WorkCentre M20i All-In-One Laser...
SanDisk Sansa Clip MP3 Player Logo
261 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
