Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Condensor overheated a piece of styrofoam got cought in the fan motor and it stopped the blades from spinning. I cleared it, but the condensoer is hot to the touch. Is there a reset or something?
  • 828 Answers
The reset should be automatic. If the fan is running now everything should return to normal after the fan cools it down.
Posted on Jun 08, 2008
Ford focus 2006 engine overheating once ac swicth is on..
Sep 04, 2011 | Ford Focus Cars & Trucks
Hello, we have an RSW2400E. We recently moved and took our refrigerator with us. We left the refrigerator off for 24 hours and then turned it on. The refrigerator does not get very cold and the food in...
This sounds like someone may have knocked the condensor fan motor connector loose or bent a fan blade on the condensor fan in the process of moving it. Open the back of the unit and check the fan blade to see if it turns freely. Clear any obstructions. If there are no obstructions check the connector on the condensor fan motor. The key here you said it was working pre move and post move this statement is a dead give-away for a condensor fan problem: The panel that splits the refrigerator from the freezer is extremely hot. You can most likely fix this yourself.
Thanks for choosing FixYa,
Nov 06, 2010 | Maytag Refrigerators
The fan motor started making a sqealing sound about two weeks ago. Then noticed a burning smell this morning. Checked it again this afternoon and the plastic divider between the fridge and freezer is so...
you indeed do have a bad condenso rfan motor.. its the fan by the compressor behind the unit,,i couldnt find your model number on my part look up, but you can call samsung direct( cust service line) and with the entire model and serial number they will be able to determine the correct part number, you want entire condensor fan assy with housing and fan blade... it will come complte, you will simply unplug and snap in the new unit housing and all.. inn meantime i would pull unit away form wall and with a desk top fan orwindow fan blow it on te compressor to keep it cool you dont want to overheat the compressor. the youll have major problems
Oct 09, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
The divider is overhot
I can tell you this..its most likely the condensor fan motor has stopped turning. it could have something stuck between the blades so remove back cover and find your fan motor..It will have a 5" fan blade on it. this is where you'll look for something between the blades. If nothing there. Be careful and spin the fan blade to see if it will start..If it does..It will most likely fail and you'll need a new motor. If you have a portable window fan or something like it...Have the fan blowing towards the compressor and leave it behind the refrigerator to keep air blowing and this will make your refrigerator freeze and cool...until you get a motor
Oct 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
My refrigerator has a burnt wire smell. The fans are running but the freezer doesn't seem as cold as it should be.
I'm guessing the condensor fan motor is not running. they smell like an electrical odor when they stop..remove back cover and see if something has gone into the blade area and stopped the motor from turning. if so, remove it ..if not, spin the blade and see if motor starts..if so, order new can use a floor fan to blow air towards compressor until you get a motor
Oct 02, 2009 | Whirlpool Refrigerators
One fan blade stopped working and is hot to touch
The motor is 'locked up' that's where the heat is coming from. It may have a bad bushing or something is jammed. Give it a good look over you may see it. Does the blade feel hard to turn?
Sep 08, 2009 | Minka Aire F602-BNCH Gyro? Fan
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Not working
if your fan is not runnig now it would be in your best interest to turn the machine off and call a service company so you don't do any damage to the compressor. you can reset macine back to default setting by turning the rf off for 4 min then turning it back on. if that does not get your fan running turn it off until a tech looks at it
Jun 07, 2008 | KitchenAid Superba Architect KSCS25INSS...
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
82 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
