My Mitsubishi CS-2005R stereo TV set has a problem with its brightness: it's too dark when a DVD player or PS2 is plugged into it, and I ave no way to adjust the brightness with the remote I have. It was not the original remote and I do not have the funds to replaceit -- and the picturesof the remote indicate that it didn't have the right controls anyway. How DO you adjust the brightness, contrast, etc. on this TV?
SOURCE: The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
SOURCE: Get into service mode
if it cannot be adjusted then there is a problem in tv. as your green color is absent you will get red+blue=purple your problem is in green video ckt please check 1 sypply to green cathode ckt 2 loose contact in crt base 3 loose signal connector 4 check components related to green cathode& green video tr. itself 5 check for green signal is coming to green video section from processor. 6 signal processor ic if you are not tech person get it done by skilled tech. it is a common problem. it is a not a major problem. please check
SOURCE: How do I fix contrast and brightness on 36" toshiba tv?
you can bring more brightness by removing cover on your tv and then you will see ther 2 button ther in back of your tv one is FoCUs and other is G2 rotate the G2 button till you see more brightness on your screen put the cover back and that is if you dont know to do that go to one authorised service
SOURCE: Monitor Brightness problem
it is still on warranty... check on service ... or you can try to download drivers .. or new chipset for your laptop..
or on startup hit f and chose last known good configuration thaht worked.
SOURCE: Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
