Question about Maytag Neptune FAV6800AW Top Load Washer
Water leak I had noticed over the past week that the softener was not dispensed at the end of the cycle. Tonight we discovered water under the washer. If this is a simple solution, please by all means let me know, I am ready to throw it out the door. This thing has been nothing but trouble for us, including having the main bearing and tub replaced, the bearing twice in two years.
  • 96 Answers
Need to check the supply hose connections. Could be that's where leak is coming from. Make sure there is no clogging of the hose.
Posted on Jun 08, 2008
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
JRR
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My problem is that the fabric softener doesn't dispense on my GE front loader WCVH6260 washer. (I rarely use the bleach compartment, so I don't really know if that is working.) The detergent part dispenses...
I know this may sound silly, but I have seen this problem solved on many occasions by cleaning the filter screen(s) in your cold water supply hose!
This is because the softener dispenser must fill with cold water (on top of your softener liquid) in order to start the siphoning off of the softener. If the cold water supply is restricted, the dispenser will not receive enough water begin the siphon effect.
Now before you tear things apart, try this test...
Begin a wash cycle by filling with HOT water, and observe (listen to) how fast the tub is filling for a few seconds... Now change the wash temperature to COLD, and notice the difference in water flow. If you detect a noticeable decrease in water flow... Clean the cold water hose screens!
How? Unplug the unit! Turn the cold water valve off, and remove the hose. (If you did the test above, you will easily feel which hose is the cold one.) Use a small brush and a squirt bottle to clear the screen inside the inlet to the washer, and also check the end of the hose where it attaches to the plumbing... some guys put a screen at both ends of the hose. Put it back together, turn the water on and CHECK for leaks. All OK? Plug 'er in and wash a load, and pat yourself on the back for saving yourself the price of a service call!
Hope this helps...
Bondo
Oct 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
MAY8700AWW LEAKING WATER UNDER DOOR AND S/B/F DISPENSER
Service came out to check out my washer. He sent it thru the wash cycle and it started leaking. He removed the top and checked the hose that leads from dispenser to tub. What he found was the round piece of paper from the clorox top which had dropped into the dispenser apparently when I poured clorox into the dispenser. Which was causing the dispenser to backwash underneath and flow down like it was coming from underneath the door. Thank God I have an extended warranty. I advise everyone who has the newer digital models to purchase an extended warranty. It is worth it....the repair can be costly from what I understand.
Jan 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Jul 06, 2007 | LG WM2277H Front Load Washer
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag Neptune FAV6800AW Top Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
