Question about Philips J44414
Webcam wont load on MSN Live
When trying to start a video call with another contact, it constantly says its loading. This happens on my end as well as the other contacts. I can see myself but not the contact. I have turned off firewalls, updated my registration profile. The contact is located in another country but we were able to use it ok 12 months ago. Please help, this is frustrating! I have a phillips webcam i just purchased. I loaded MSN Live Messenger and am trying to have a video call or share my webcam with my brother who is in the military......my camera is working fine but when i try to share or connect with a video call, it just shows loading..... and then finally timesout and never connects. HELP PLEASE!!!
  • ARTI-79 Jul 16, 2008
    Hi, i have a problem with my camera when trying to share with the other person they cant see me and i cant see them either, the camera works and i can see my self but they cant se me, try couple deferent cameras same thing no change i reistall MSN and more i even toke my computer to the repair computer shop they cant figure it out, but it does works in other webs chats like yahoo etc.. but only on MSN dont work . PLEASE HELP ME been trying this for 3 weeks now!! THANKS .
    Sergeant:
  • 284 Answers
I found its just not firewall. your port is being blocked, some company have blocked ports in some cases.
but check to see if you have norton system works or norton 360. if you do then its probably more than just firewall.
I myself dont like these program, they have always cause trouble.
try shutting them off completely. and then try it
Posted on Jun 07, 2008
IBM Ultraport camera
First of all make sure you have the webcam drivers installed on your pc.Next install the MSN messenger,login to your account and then click on Webcam icon under the display picture and then click send/show my webcam.After the person at the other end accepts it they will be able to see you.
You can also click on contact name (the email id of your friend on the list) with right button. Then select video and click on Start a Video Call.
Thank you for using fixya.
Dec 19, 2009 | IBM UltraPort Camera II Webcam
Cam wont work om windows live but works on my yahoo account
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Nov 27, 2009 | Computers & Internet
Webcam problem on windows live messenger 2009
there could be the problem with registry keys conflicting with each other,
Tools > Audio and video setup...
Follow the instructions on the setup screen and once its finished, you will find that the webcam should be able to show up.
If it doesn't show the webcam on the other person, tell him to switch his status to busy for 5 seconds and then back, hopefully that should come up on the other persons screen.
If this hasn't work in most cases it should work - You will have to downgrade to Windows Live Messenger 8.5 and hopefully it should work.
If this hasn't work, go to the HP website and search up webcam drivers for your device and then install it on your computer - Hopefully your webcam would work.
if it does not work then you have to download reginout registry cleaner to fix this problem
Nov 04, 2009 | Microsoft Windows Live Messanger
Integrated webcam wont work on MSN Live IMer. Nor can I view other contacts webcam's. It pops up and I see my face but they don't see mine, then a minute later it says the webcam session has ended.
do you tried click on broadcast
and you need to send an invitation to your contacts to view their webcam and they have to send you an invitation as well then accept
or decline appear on your screen
Oct 22, 2009 | HP Pavilion dv9000z Notebook
VX-6000 is not recognized by Messenger or Windows Live
Have you tried to set up the webcam via yahoo or MSN. Go to the options menu and select webcam. It should ask you to select a device to use as your webcam. If it is available select your webcam and continue setup. You will have to do this with both yahoo and MSN
Jun 15, 2009 | Microsoft LifeCam VX-6000 Webcam
Webcam trouble
okay
uninstall your msn reinstall then in the file on your msn beside where you add contacts click the arrow then tools then setup audio and video.
Then exit msn and restart
This seems to be a constant problem with msn and built in cams
what type of camera and what laptop
Jan 04, 2009 | Acer Aspire 5100 Notebook
I also have the same problem, This goes in right with my voip connection being unable to get past the modem.. help!!!
Oct 13, 2007 | GE EasyCam Webcam
I cant see my contacts webcam
uninstall all of programs you use to install your camera. After the uninstall plug your camera in and wait for the system to ask for your drivers, load your drivers and reboot your machine. If your drivers can run in a 16 bit emulation on a 32 bit emulation then you are good to go, if not well welcome to the world of vista.
Sep 25, 2007 | Trust SpaceCam 320 Webcam
Webcam and Live Messenger
I can use the webcam on Skype but when I close Skype and open Instant Messenger I get a message that the webcam is unplugged or being used by another application.
Oct 28, 2006 | Labtec 961307-0914 Webcam
Philips J44414 Logo
932 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
