Xerox Phaser 3100MFP/S Laser Printer Logo
Posted on Oct 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The xerox machine shows the massage "PRINTER ERROR,,,FUSER TEMP". It shows the same message whenever it is opened. And please tell me that actually due to what problem this message arises. The model name is Phaser 3100 MFP Product. Please help me with a solution.
Nikolay Boychev
Level 3:
  • Xerox Master 525 Answers
  • Posted on Jan 20, 2011
Nikolay Boychev
Xerox Master
Level 3:
Answers
525
Questions
Helped
315173
Points
1297
Disassemble fuser and inspect thermistor and heat lamp. Then replace broken part.
Xerox phaser 7760 not detect the missing fuser, image units
there is nothing to look for it told you it is past the end of it's life so buy a new unit
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
1helpful
2answers
How to Slove Fuser Temp. (XEROX 3100 MFP)
I have been struggling throughout the night to remove the Printing error Fuser temp following the suggested given but all were in vain. By accidently I managed to remover the error message by pressing # together* then switch on... super! vilho nhoni from Namibia
2helpful
I am having xerox 3100 mfp,and since last 4-5 dys massage on the screen is displayin FUSER TEMP. how i can get rd of this? pl help
Fuser problem is that the thermistor can be damaged due to overheating Fuser thermistor or try to replace the entire fuser, clean electrical contacts which could cause malfunction of fuser.Este indicated a specialist to handle this
The fax shows a messages saying "open heat error"
On this machine, you may have a fuser assembly that is bad. Replace the fuser modual.
If this doesnt work, then the main board needs to be replaced.
Also what most people forget is the fuser fan. Sometimes it turns slow and you will not even notice it. It might not even turn at all.
Replacing the fan will solve most problems, but if it still does not turn on, Look on there to see if it has a small circuit board on the fuser fan, replace it too.
if all else fails the main board needs to be replaced.
Good luck
83helpful
5answers
Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
1helpful
2answers
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
8helpful
3answers
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
1helpful
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
