MP3 and Digital Media Players
Problem for MP3 and Digital Media Players
Generic problem for all MP3 and Digital Media Players
MPEG codec for MP3 player: Philips SA52XX
By xcaribenitox on Jun 07, 2008
I recently purchased this Philips SA52XX MP3 player with the hopes that I could watch movies while out & about. I have DVDs that will allow for download but after attempting to convert the DVD files to an acceptable format with the accompanying software; Media Converter 2.5, I continue to get the error message stating that I do not have the correct MPEG codec and that I should go to wikpedia.com to download this codec. I have downloaded multiple codecs to include DivX, Mpeg streamclip, Final Codecs 2008, etc.....Nothing seems to work. I really need assisatnce or I see no other recourse but to return this product.
Same Problem
Apr 23, 2009
-   I have same problem with  Philips SA52XX. I canť tranformade films to ma recorder, so i can't watch it outside...  -   Guest
Apr 15, 2009
-   I got given the Philips Go Gear SA52XX and having a problem with putting music on? Ive tried it throught Windows media player and tried drag and drop but nothing will seem to work. Also when i turn it on, it will eventually freeze and i hav to reset the MP3 player. Please help! Thanks -   fluffiez
Apr 09, 2009
-   same as his -   Guest
Mar 28, 2009
-   my mp4 player i have downloaded mp4 and it still won't work-   expantion_pa
Jan 17, 2009
-   i have the same problem...how can i solve this..?only buying thier stuff...30 $ ?! neah...-   Guest
Best Solution
posted on Jul 29, 2008
Helpful)
mcnig
Rank: Apprentice
Rating: 95%, 9 votes
Hey, i got on here and had all the same problems....i finally got it to work.... i think that the video converter software that they give you is bad...hahahaa...after a couple of days of messing with it....i got it to work in windows media player....its on one of my older computers....and it let me convert the video...it takes a long time but it works.....as of right now im putting 3 skate videos on it right now...get on it...
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Aug 06, 2009
Very Helpful)
happydude807
Rank: Apprentice
Rating: 100%, 1 votes
Hi people. I had the same problems.
Uninstall Media Converter and any codec packs you have.
Install K-Lite Codec Pack 5.0.0 (Full)
Reinstall Media Converter
The converter plays havoc with Windows Explorer 8 so you need to uninstall it (control-panel-uninstall programs-updates) then reinstall it when you have installed the codecs and the converter.
Hope this helps
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on May 07, 2009
Very Helpful)
Seritath
Rank: Wiz
Rating: 81%, 56 votes
The phillips SA52XX is a harder machine to work.Unless you go on rhapsody,which I think is mostly unfair that you have to keep paying to make the thing download,you have to have a video converter,which for most people are very hard to use.Personally my solution is to use limewire.I go onto limewire set it so it shares what I download,or share it manually and pull up a windows media player at the same time.For music files every type works.Video files are tricky.What I have found is you have to look up the name of the video and then type Mpg or Mpeg.Then,hopefully,it will spit out atleast one or two relatively good videos under the file format of Mpg or Mpeg.Otherwise I have not found anyother way to convert and download.
Was this helpful?
Yes
No
Solution #4
posted on Nov 30, 2009
Not Rated)
hlgtfg
Rank: Apprentice
Rating: 0%, 0 votes
display showing NANO Match Fail
Was this helpful?
Yes
No
Solution #5
posted on May 18, 2009
Not Rated)
zsyljj007
Rank: Wiz
Rating: 74%, 8 votes
Eztoo Video Converter supports almost all video formats as source files and outputs many different video and audio formats beyond HD (high definition), including MPEG, AVI, WMV, MKV, RM, MP4, ASF, iPhone, iPod, MP3, WMA, WAV, OGG, RA, AAC, AC3, etc. You can download this software free from here: http://www.eztoosoft.com/video-converter... For mac users: http://www.eztoosoft.com/mac-eztoo-video... Hope it helps. Contact me if you have any other question.
Was this helpful?
Yes
No
Solution #6
posted on Mar 29, 2009
Not Rated)
esok20
Rank: Apprentice
Rating: 0%, 0 votes
Hey there philips user i may have a solution that will work for you instead of trying to get the MPEG-4 codec to work try using a WMV files it has always worked for me when i do this
Was this helpful?
Yes
No
Solution #7
posted on Dec 28, 2008
Not Rated)
jimmykins
Rank: Apprentice
Rating: 0%, 0 votes
If you download AVS4You software navigator and download avs video converter 6 from the list, you can convert your dvd to a format that will download onto your phillips sa52 player. If it is the trial version it will have a logo keep popping up to spoil the result on your player...you need to pay about £25 for the full version for a year or about £35 for unlimited useage. You can only use the licence on one computer. If it breaks down or you lose everything you can still download again onto that computer...BUT...if you change your computer you need to buy another licence...otherwise it works great.!! hope this helps...JIM
Comments:
Jan 07, 2009
- Alo AVI MPEG WMV 3GP MP$ Converter is the one I have settled for. It cost me £18 and I have put it onto two computers for no extra cost. They will send you a CD if you request one.
I just open the file where it says 'add files' at hte top left hand corner of the application when you open it. Next..you click CONVERT at the bottom. it takes about two or three minutes.
after closing the application down, you open your phillips converter which you should have installed when you bought the iipod. you then add the files you have just converted (you should have made a note of the output folder so you know where to find them) Next ..you just click 'start' the phillips converter now prepares and transfers the files onto your ipod which you should have connected to you computer. When you remove the USB from your ipod it will update your ipod and you will find 'your video under 'Videos' I use windows media player for music and pictures. make sure you deselect automatic sync first..find your files, right click and add to sync list and then click syncroniise. It took me ages to figure it all out but it works great now.best of luck...JIM
Was this helpful?
Yes
No
Solution #8
posted on Oct 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Put the Phillips player in the bin that will sort it!!!!!
Solution #9
posted on Sep 21, 2008
Not Rated)
Alfredoled-z
Rank: Apprentice
Rating: 0%, 0 votes
Ummm all you have to do is get a WMV codec.
Use atubecatcher to get videos from youtube.
Wichever videos you want.
Was this helpful?
Yes
No
Solution #10
posted on Sep 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try prism video converter software the trial is free for two weeks and u can convert anything to anysize
Solution #11
posted on Jun 07, 2008
Not Rated)
ThaMp3Doctor
Rank: Guru
Rating: 86%, 4758 votes
Get the latest version of Quicktime, and let me know if it does the trick.
Was this helpful?
Yes
No
Popular Solutions for MP3 and Digital Media Players
Questions and Unsolved Problems for MP3 and Digital Media Players
Answer
My brother's life has its own soundtrack. He has a Walkman E Series MP3 Player and I'm looking for... (More)
Answer
How to down load muliple songs from a sansa fuze 8 gig. Please list all of the IMPORTANT steps
Answer
my ipod touch internal speaker quit working today and a song will not even play until earphones are... (More)
Answer
is it possibe to put videos and watch them on my gogear vibe mp3 player. please say yes. if u email... (More)
14 Other Users Have The Same Problem - Continued
Comment by shantheman88, posted on Jan 13, 2009
I have the same problems with my videos. Also my computer wont recognize the device. I can put music on to it but i have to do it an entirely different way to what im used to. Can someone help me find my player on my computer!!!
Comment by Guest, posted on Jan 10, 2009
sexy jool
Comment by gizmo_x, posted on Dec 20, 2008
when i try to use the philips media converter , it states " one or more people are using this please try again later " !!?!?! i dont understand what it means when im the only person on it ? .
pleazse help  thanks james
Comment by clo-bow16, posted on Dec 03, 2008
I have today purchased the Phillips GoGear however i am very frustrated at the fact that i can not get any music video's on it. I have the media converter 2.5 for phillips, i go to add file or dvd click start and i get a message saying a do not have to updated codec. i have downladed many types of codec's tried but still it will not allow me to do what it is designed to do. Please let me know what to do in order to get it working.
Comment by byuva4u, posted on Aug 08, 2008
Philips is simply waste . just now i bought my philips mp4 player . i am unable to convert my favorite videos to player format . and the sound effect is very low than other ipods.
Comment by Guest, posted on Aug 06, 2008
i dont see my video clips
Comment by Guest, posted on Jul 29, 2008
same problem... i can't convert videos with media converter
Comment by stung, posted on Jul 16, 2008
i have a mp4 made by simushi every thing is working exept the videos. I download two(2) vids and i cant see them.
Comment by syanah, posted on Jul 15, 2008
I have kinda the same problem. when I try to convert a .WMV file, the converter shuts down. when I try a .MP4 file the convertion stops after a few seconds and I get a message saying that I don't have the MP4 codec installed on my computer.
because I thought it might be something on the computer that's causing this problem, so I installed the software on an other computer. on that one it never shuts down, but I can't save the converted files. :S
I'm now using a different converter program, but I can't play the videos on my SA52xx. I was wondering what the settings are if you want to convert files onto the GoGear.
Describe your MP3 and Digital Media... problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in Las Vegas, NV
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
