Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
KV35540 Sony Trinitron
Hi, My tv just has snow. I can change channels but everything is snow. I checked the hookups and everything appears fine. Can I repair this?
    Problem Solver:
  • 5 Answers
Pls check the antina or the cable line or the cable plug or call the tech.
in the tv tunner foulty
Posted on Jun 08, 2008
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Hi, I have an old sony trinitron ku27ts27 and out of the blue yesterday it went to snow on me it's not the cable system, how can I get to somesort of setup menu when there isn't a setup button? Thanks...
Try knocking on the cable connector whith the cable pugged in and the set on and also put the tv on a channel between 2 and 13, if the picture comes back then you have bad solder joint in or around tuner ***`y. you may also want to check you cable connectors. the tv setup won`t help you here. good luck
Oct 31, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Hi I have a sony Trinitron TV and after its been on for several minutes a memory stick error message appears on the screen, if you click to change channels it dissappears again, but this continues to...
the manual doesnt say anything about disabling the memory card slot.
common advice would be
If you have a memory card plugged in take it out while you are watching something else.
If you dont have one pluggged in while you get the message, plug one in?
Oct 12, 2009 | Sony FD Trinitron KD-34XS955 34" TV
Sony Trinitron: Frozen Static Issue
you could be experiencing two problems. the first part of your description states the static with two horizontal bars, this problem is usually erratic and it is caused by a defective varactor tuner(this happens while watching a channel thru your channel selector) the second part that it also happens while using the front hookups could be taht the front input connectors have developed some loose solder connections and thus the video problems (very common problem)
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY KV-27FV310 FINE TUNING
AUTO PROGRAM YOUR CHANNELS. IF PROBLEM PERSISTS REPAIR OR REPLACE TUNER.
Nov 03, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony WEGA
It is TV problem in Tuning section hardware.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Bad reception on lower channels
Hello Moeggy,
Tuner of your TV set got defective and need to be replaced. Pls contact nearest Sony service shop for replacement of Tuner.
May 08, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony TV snow at startup
Bad solder connection in tuner.....replace with new or rebuild.
............................T.
Mar 09, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
