Question about Kenmore Microwave Ovens
Kenmore Microhood 401.80089 - L SE L error
I have a Kenmore Microhood 401.8009, 1.7 cu feet, 1100 watts.
After cooking some baked potatoes on the sensor setting this evening, the microwave completed its cycle and beeped when ready. We ate the potatoes, and when it was time to clean up, the screen said "L SE L" where the "L" are small and super script. (it may be "5E" not sure). No buttons work. I unplugged it for a while, and when replugging the screen lists the familiar "PRESS CLOCK TO .." and then beeps three times and back to the "L SE L".
Any ideas?
  • egerrits Jun 11, 2008
    Thanks. I'll see if I can get Sears to repair it...
  • Anonymous Mar 21, 2014
    I am having the same issues listed with my kenmore microwave. It all of a sudden started beeping out of no where. I unplugged it and left it unplugged for hours. When I plug it back in, it asks me to set the time, but then either beeps again or now it currently has SE displayed. It's complete model number is 401.80089700
  • Kenmore Master
  • 9,098 Answers
The 401 model prefix means it's actually made by Samsung.
On some Samsung models, there is an odd SE error message that seems to be vexing a lot of people.
It's probably a sensor going bad, or maybe scrambled code in the microprocessor, but it's odd.
There is one discussion of it here.
I hate to say it, but since it's a Kenmore brand, you're going to have to call Sears for service.
You can find them at http://www.sears.com
I really hope they can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
  • William Miller
    William Miller Jul 21, 2008
    UPDATE
    The -SE-error is a shorted keypad.
    If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
    If you would like to have us do this for you, we do that for $39.95 plus part costs.
    Please feel free to contact me directly if you need more help.
    We're happy to help you and we'd appreciate your
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
    New Friend:
I have the same model and after 3 years of good service the SE error popped up. After watching some YouTube videos and preparing myself to order a replacement membrane panel, I tried taking it apart (wiping off all the grease that had accumulated .. ewww) and put it back together. Was successful and works perfectly again. Just need a phillips screw driver and patience to figure out how to remove the plastic panels and get at the control panel ... it's not hard to fix this yourself .. even if it means having to order a new control panel.
Posted on May 03, 2015
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Door does not close
Did you try forcing it? It might have been badly engineered. refer to your warantee
Feb 16, 2014 | Kenmore 8503 White Microhood Microwave 1.6...
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
We are getting an error code of 5E. Microwave automatically turns on to bake a potato.
"SE " means your membrane keypad is shorting. And it is specifically the baked potato key that's shorting.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking. Better still, unplug it and do not use it.
We would need the model number in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions or contact us here for free assistance.
Sep 18, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Cuts off when gets too hot
inside your microwave is a heat censor, if it cuts the microwave off then its to hot for safty have a good look round the back of it to check that the air vents are all clear and that a good air supply can get all around it when its cooking food,,, iv seen so many microwaves tucked away into a small place, and they will all cut out when they get to hot,,,1100 watts gets very hot too!
Jun 06, 2010 | GE JES1142SJ Microwave Oven
Kenmore Microhood not working
I think it may be an internal fuse or a fusible link. You also have a series of contacts and switches inside that are set in place by the mfr. for safety. You could get it repaired for 50-75 dollars or a new one for 125-150 dollars. If you have checked the internal fuse, then just get a new one if the other one is older than 3-4 years.
Jan 11, 2009 | Microwave Ovens
Did I blow it up????
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Ray
Oct 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
1,158 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
