Question about Dell 20GB NOTEBOOK HARD DRIVE KIT FOR LATITUDE C,CP,CPi,CPiA SERIES (20LCPD)
Dosplay I switched hard drives from my acer laptop into a dell latitude CPi, now I can't get the display to change from 16 color to 256 colors
Probably have to go to dell and download video drivers for your latitude
Posted on Jun 09, 2008
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I have just brought dell latitude e5500 laptop. i wanted to connected the hp officejet 5610 scanner to my laptop but am not able to do. please help
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab19
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
May 30, 2009 | eMachines W3611 PC Desktop
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Laptop won't display more than 16 colors
Go to the DELL WEB site www.dell.com
Make sure you download the correct operating system drivers for your model laptop.
To search for the correct drivers by use the Service Tag number, this is printed on a label on the bottom of the laptop, it is also displayed in the BIOS.
Dec 31, 2008 | Dell Latitude CPX Notebook
256 colors
why you want to change in to 256 colours if you change it your display colors will be change 16 and 32 is high colours and 256 is true colours then your games does not work on 256 colour or softwares also
reply me if you want to change
Sep 27, 2008 | ASUS P5RD2-VM Motherboard
Dell Latitude C600
Yes, No problems as I put a 100GB drive in the LS model micro Latitude!
Aug 06, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Hard Drive is not showing
Just chk all the connections to the drive and make sure they r fixed and tight.
Incase it still exists try ur HDD with some other system.
and if it still does not work then probably ur HDD has crashed(BADLUCK!)
Jul 08, 2008 | Dell Latitude CPI Notebook
Computers & Internet Logo
141 people viewed this question
Alun Cox
