Question about Aiwa CDC-X504MP CD Player
Stuck in demo
Was driving today, and switching radio stations and somehow it switched me to demo mode. And I have tried everything to get it to work. No buttons work, and I have tried holding down push-menu as stated in the manual. Reset doesn't work either, any help at all would be appreciated
Thanks
  • 6 more comments
  • Anonymous Jun 18, 2008
    IN DEMO MODE WILL NOT COME OUT OF DEMO MODE TRIED RESET TRIED POWER OFF AND ON CLEANED FACEPLATE CONTACTS STILL DOES NOT WORK PLEASE HELP WITHOUT PAYING 19.95 CHARGE
  • bb1385 Aug 31, 2008
    i am
  • voyagerff Oct 29, 2008
    Same problem, stuck in demo mode. User guide instructions don't work for my case. (Press-and-hold "push-menu" never results in an option to turn off demo mode.)
    Anyone have any other ideas?
    voyagerff@gmail.com
    Collinsville CT
  • Anonymous Dec 08, 2008
    I also had this just happen. If anyone has any other ideas please let me know!
  • Anonymous Dec 11, 2008
    I am having the same problem. Anyone have an update on what to do?
  • lisek16 Dec 11, 2008
    I've had my AIWA CDC-X504MP for 4.5 years and it was under a 4 year best buy warranty. I was in the middle of changing stations and this happened. Tried Reset and several other things - only button that works is holding down "display" will let me reset the clock - otherwise nothing else works. Does anyone know - is this a fuse issue? I haven't seen anything else online on what to do. I'm planning to get a new car within the next year so I'm not looking to spend 200 on a new cd player if I don't have to. Any ideas?
  • Rouad Jan 09, 2009
    I also have exactly the same problem with the player stuck in demo mode. I can only get into setting mode of the clock. Otherwise none of the buttons work. Can any one help?
  • smt1 Feb 13, 2009
    My daughter has the same problem with the CDC-X504MP - display is stuck - i've tried the solutions posted but no luck. please help.
I had the same issue and was about to give up.
cleaning, key combos and such didn't work out.
Solved the dirty way, as described some comments above:
"Just took the faceplate from the "push-menu" button and hit it against a hard surface [not too hard but not too soft hits] and thats it, it worked again."
ah, the good manners!
Posted on May 07, 2009
All this week long my Aiwa CDC-X504MP won't work at all, same situation than you all. Tried to make up some button combos with no avail. An hour ago i made it work again. How? Just took the faceplate from the "push-menu" button and hit it against a hard surface [not too hard but not too soft hits] and thats it, it worked again. Not a good "solution" that is, but it's working again.
errr hope it helps. bye
Posted on Nov 10, 2008
Any update on this? I'm having the same problem with my Aiwa cdc-x504mp receiver.
Posted on Sep 03, 2008
I've had the same thing happen to me twice. Unfortunately I don't remember what button(s) I pressed to fix the problem. However, I know that I was holding down the "source" button as I pressed another. It seemed like I held it down for a little while then it turned on. There must be something wrong or a weird button combo in order to turn it into demo mode. I'll post again if I can figure out what I did before to fix it.
Posted on Jul 14, 2008
I just fixed mine. I think it's something with a security lock. My default code seems to be with 6 and 5, so by hitting 665 or 655 I got my radio back to fully function. When this whole mess started I had gone from my radio station set at 6 to 5 and must have hit the buttons in such a way it activated a security lock that only allowed me to change the time or view the demo. Hope this helps....
Posted on Dec 12, 2008
  • Joe Burton
    Joe Burton Jan 09, 2014
    My solution was similar to this, and I think it may be a security thing. I read a lot of tips, tried everything and then just started pressing the 1-6 numbers a hoard of times, randomly, then pressed the far right double button source/mode and all the sudden I heard the antenna raise up and it worked.
  • 34 Answers
1. While in Demo mode push and hold the "PUSH-MENU" button until "set" appears on the screen.
2. push "Seek" + or - to select Demo
3. turn "PUSH-MENU" to select "demo off" (turn the volume knob)
Posted on Sep 10, 2008
Every Button Switches Between Radio and CD
Reset the radio by pressing a sharp object (pin, pen, etc.) into the small reset hole on or behind the face. If it doesn't have one, disconnect the negative cable from the battery for two minutes and reconnect. If you still have this problem, the radio is bad.
Apr 18, 2014 | Panasonic CQ-DF203U CD Player
I have a jvc kd-r45 it will not recall any pre set radio stations after it is switched off and demo mode kicks in every time i start it up. Tried reset any ideas?
I don't think you have the memory keep alive wire attached to a constant 12V+ source. This is why it is not keeping set stations and reverting back to demo more every time it is switched on. Usually the memory keep alive wire is yellow.
Jan 18, 2012 | JVC Car Audio & Video
I have a kenwood radio and the radio wont switch off demo mode no matter what i do. I have looked at all wires etc and it still wont save preset stations or settings.. Its driving me mad! When i bought...
if it isn't saving stations you need to make sure the yellow wire is going to a constant power source. without knowing what brand or make of radio you have, it is hard to say how to turn off the demo mode.
Mar 22, 2011 | Car Audio & Video
Goodday I have an Aiwa CDC R104. The radio ceased working, remaining in the demo mode regardless of the button pushed. It does not switch on. I tried the reset switch and also disconnected the unit...
there are tags put on the radio from the factory and held in my screws. those tags do screwy things sometimes. i had a radio that wouldnt power up, and one in demo mode.
Aug 17, 2010 | Car Audio & Video
Garmin Rino 530 stuck in DEMO MODE
Try a hard reset....with power off hold enter button and page button while turning on unit ....this should reset to factory setup, should now be able to switch out of demo mode
Jun 11, 2008 | Garmin Rino 530 GPS Receiver
Demo mode Kenwood KDC-237
To turn off the demo you need to press the src button to put it in standby mode. Then press the menu button as if to change the settings and use the joystick to scroll right until you see demo, then turn it to off....
Do as above to allow you to enter AUX mode this will let you plug in your MP3 player to the input on the face and hear music through it ;)
hope this helps you
philzee
Mar 18, 2008 | Car Audio & Video
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Jan 16, 2008 | Aiwa CDC-X304 CD Player
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Jan 03, 2008 | Televison & Video
Stuck on DEMO Mode
Just try to initialize THE plager again. Without cd in the player switch on the power while pressing the Play, Open and Next Track button. On the display it says " initialized" Ready. Frits van Heekesen Nijmegen The Netherlands
Dec 27, 2007 | Denon DVD-2200 DVD Player
Demo mode
Hi... your radio has 2 power wires. One is red and the other is yellow. Check for power on both of these wires with the key on. If both have power then you probhably have them switched around!! (one is constant power for memory to "remember" the settings, the other is key on power to that the radio knows the ignition key is on or off. From the sounds of what you are describing it sounds to me like you have your wires switched around...
Sep 10, 2007 | Sony CDX-S2010 CD Player
Aiwa CDC-X504MP CD Player Logo
1,247 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
