Question about Video Game Consoles & Games
My psp presses buttons by itself ex:volume turns up by itself.when i go online it presses circle which makes me exit
  • Anonymous Jul 30, 2008
    me too but it presses select by itself and mutes itself
Um y don't you try puttin the psp on hold and off hold i have the same problem
Posted on Apr 16, 2009
How to add music onto my psp online
    1)Connect PSP to computer with USB supplied with PSP.
    2)Now, press "home" button on PSP
    3)Scroll down menu to option "setting" using right and left directional buttons
    4)When you reach the option "USB Connection", press X button to indicate your selection
    5)The "my computer" window will now show a removable drive
    6)Double click on removable drive to open it. You will see a folder named "PSP" inside it.
    7)Open the folder "PSP" and see whether there is a folder named "Music" inside it.
    8)If you cannot see the folder named "Music", then create it inside the folder named "PSP." Make sure to name it "Music".
    9)Now simply and paste the music files from hard disk to the "Music" folder, just the way you would transfer files from a CD to your hard disk.
    10)Once you are done, press the "o" button on your PSP. PSP will exit from the USB connection. Now unplug PSP from the USB data cable. Now you can carry around your music collection and listen to your favourite tunes, whenever you want. Enjoy!
How to put music on PSP from computer
Oct 31, 2015 | Sony PlayStation Portable (PSP) Console
Tip
Play psp games on tv via composite/component av cable
you will need to have:
1.a psp slim with custom firmware 3.80 or 3.90.
2.composite/component av cable.
3.installer plugin file FUSA that can be sourced in the internet e.g. qj.net.
4.memory stick pro duo with 2 gigabytes capacity.
steps:
1.source the FUSA installer file.
2.once sourced,extract it to your pc desktop using 'winrar'.
3.connect pc to psp via usb.
4.upon extraction,copy or drag all four files (prx and txt) to the 'seplugins' folder on the memory stick (ms0:/seplugins/).
5.if you don't have the 'seplugins' folder on the root of the memory stick,create it.
6.exit usb connection and completely turn off psp,then turn it back on while pressing the 'R' button to go to recovery menu.
7.on recovery menu,choose and click plugins,set the FUSA plugin to 'enable',then exit recovery menu.
8.you can also activate the plugin on the FUSA menu itself,and this is better recommended.
9.connect now psp to crt tv using component av cable.
10.load a game and after loading it,just right before clicking the 'start' button to begin play,exactly at this point,simultaneously press on the volume - and + buttons to bring out the FUSA menu.
11.after a few seconds,the FUSA menu will appear on the psp screen,change the settings accordingly,exit FUSA menu and start the game to play it on your tv.
*many games or emulators will work but not all as the FUSA file is still in its beta stage,you need to figure out which one will work or not through trial and error.use caution,this guide works but no guarantees.
*used a 2 gb memory stick pro duo as 4 gb didn't work.
*used on an interlace only tv and not progressive or crt/non-flat/lcd/plastma/hdtv's.
thanks.
on May 05, 2008 | Sony PlayStation Portable (PSP) Console
Hi, I got a PSP 3000 and the circle button is pressing by itself, it seems something under it are stuck to the MotherBoard but im not sure what the real problem is. Now I can't play games because every...
Hello.
You need to open up your PSP (But it will void the warranty!) remove the circle button and then make sure there is no dirt under it, then replace it back. It is not that hard to open a PSP, you can find many videos on how to do it.
Aug 03, 2011 | Sony PlayStation Portable (PSP) Console
How do I turn the flash off?
  1. Press 'down' key (which is located below SET button) once.
  2. Use 'left' or 'right' key to select mode with crossed flash symbol in a circle ('flash off' mode).
  3. Press SET button to submit selected mode
  4. Make photos
Jun 19, 2010 | Casio EXILIM EX-Z1000 Digital Camera
How to incres volume of psp
Follow these steps to increase the volume for your PSP-
(1) Turn on your PSP and start playing your movie, song or game. Boost the volume of the PSP by pressing the volume control buttons located on the button bar, which is below the screen. The (+) button will turn the volume up, and the (-) button will turn the volume down.
(2) Plug your PSP into a larger speaker if the volume still is not high enough. You need an auxiliary cable with two male ends to plug the PSP into a speaker. You can use a three-foot cable. Plug one end of the cable into the PSP and the other into the speaker input.
(3) Plug any FM transmitter into the PSP headphone jack and tune your radio to the FM station on the FM transmitter. Your audio from the PSP will now be playing through the radio speakers in your car or home. This will allow you increase the volume greatly.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 06, 2010 | Sony PlayStation Portable (PSP) Console
On my psp the sound went to blank i put the sound to full and it goes down to none by itself
It maybe because the button for reducing the volume may have been pressed too hard in the past that the button had gone in so whenever you leave the volume incresing button it starts decresing by itself.
Jan 27, 2010 | Sony PlayStation Portable (PSP) Console
My psp volume button will not work can you help but its only the one to turn it up not down
When this happens, it's because the volume button on the inside is messed up. Usually it's because it's dirty or sticky and sticks down [or presses itself]. You can try opening it and cleaning under the volume button. If that doesn't work, you may need to replace the home/volume/start/select circuit ribbon cable. If you're not comfortable opening it, check the following company -- they would repair something like this for $29
http://store.richspsxparts.com/clforpsprese.html
Nov 16, 2009 | Sony PlayStation Portable (PSP) Slim...
My psp keep going to home by itself.
When this happens, it's because the home button on the inside is jammed. Usually it's because it's dirty or sticky and sticks down [or presses itself]. You can try opening it and cleaning under the home button. If that doesn't work, you may need to replace the home/volume/start/select circuit ribbon cable. If you're not comfortable opening it, check the following company -- they would repair something like this for $29
Oct 24, 2009 | Sony PlayStation Portable (PSP) Console
Buttons Dont Work?!
Hi, i just have same problem, i've changed low button bar part. It solved!
hope it will help.
May 15, 2009 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
107 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
