Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
TV PROBLEM I GET A RAINBOW SCREEN THEN IT SHUTS OFF AND THEN THE TIMER LIGHT COMES ON.
    Problem Solver:
  • 5 Answers
This the the prob. of system ic prb.
Posted on Jun 08, 2008
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
Tv comes on with sound no picture,timer light stays on for about 20secs,then lamp light comes on stays on as tv shuts down,we are stomped,cant fix prob with no screen.
The first question i need to ask is Have you removed the bulb to check to see if it has blown. If there is no visable signs that it is bad then replace it and make sure the door is secure. Secound thing you can do is retrieve the error codes. To do this press and hold MENU and INPUT button on the front of set. The timer light will flash then pause then flash again denoteing a 2 digit code. this will maybe point the way to possible problem
Apr 22, 2011 | Mitsubishi WD-60735 Projection Television
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
Rainbow showing up at bottom and top of screen creating double and triple vision
IM GUESSING ITS A LAPTOP SCREEN OR COMPUTER IT COULD BE SOME WATER TRAPPED INSIDE OF THE SCREEN LIKE CONDENSATION WHICH COULD MAKE A PRISM OF LIGHT LIKE WHEN YOU SEE A RAINBOW BECAUSE ITS SUNNY AND RAINING
Oct 08, 2009 | Philips TV Tuner Video Capture PCI Card -...
Rainbow screen then powers off
The degausser cricuit may be the fault. The degausser coil may be staying on, and thus forces a shut-down. It is also possible to have a power supply fault that can cause a similair effect.
The set will need shop service.
Jerry G.
Jul 22, 2008 | RCA TruFlat 27F520T 27" TV
TV will not turn on
check the resistors and capacitors in vertical section of the television..or change the vertical ic.
Dec 29, 2007 | Televison & Video
Sony tv
the trouble of your tv is memory
Oct 15, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
