FixYa.com
Tags:
Hard Drives
Generic problem for all Hard Drives
Power supply (by 2 users)
posted by vsen on Jun 07, 2008
The HD does not work spin.
Looks like the power pack is not working.
the user manual says 5V AC can be be used.
plaese davicee
//sen
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by dodo2438, posted on Jun 09, 2008
My fan don´t work!
Power supply is ok, led diode is shining, but fan have not power supply from board ( Desktop Hard Drive Hi-Speed USB 2.0 1TB zn.IOMEGA ).
Clarification Request
by worldvet, posted on Jun 08, 2008
The voltage to you hard drive is DC and the amperage supplied must be on demand. So do not use anything other than the supply power pack.
If you don't have a drive ready light and any activity light you do need to return this for replacement or warranty service.
There is no user serviceable parts.
Tell me who made your external drive and I'll supply you with a phone number.
Regards,
Worldvet
Solution #1
posted on Jun 10, 2008
Not Rated (0)
burns-o
Rank:Wiz Wiz
Rating: 82%, 63 votes
try a different Adapter for the HD. if it don't work then, the HD is bad.
try another socket on the board. if not working then. you can get a 3 pin to 4 pin fan adapter to power the fan from the power supply. if still no spinning, the fan is dead.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Apple (M9741GA) 400 GB Hard Drive Buffalo Technology (HD-HB160U2) 160 GB Hard Drive Buffalo Technology 750GB USB SATA 2.0 HD DS 750 GB Hard Drive Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM 160 GB SATA Hard Drive Fujitsu Desktop MPG3204AH 20.4 GB Hard Drive IBM DDYST18350 18 GB Hard Drive IOGear (GHD125C40) (DHGHD125C40) 40 GB Hard Drive
Can you Help with these Hard Drives problems?
Hitachi 500GB External USB 2.0 Hard Drive
Worked fine on my macbook but...
My Hitachi 500BG External... Answer This...
Iomega Silver Series 320GB 3.5 External -...
hi i hope you can help. i put... Answer This...
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB...
160gb samsung sata II
Does not boot into windows... Answer This...
Acomdata HybridDrive E5 Hard Drive
E5 Hybriddrive slows down...
When I connect or turn on my... Answer This...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata 750 GB Hard Drive...
I can't install the External... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
