Question about Compaq Presario M2000 Notebook
Display monitor computer powers up but get no display except slight shadow in back of screen. however if you jack to another monitor you get display
  • starays001 Jul 01, 2008
    when i turn on my laptop..certain bands of line appears on my lcd..but when i switch to an xternal monitor it works fine! what could be the reason?
  • 159 Answers
You may need a inverter
go to ebay
type m2000 lcd inverter should cost $max 20
i have it here but maybe too far
jamaica
thats the solution to your display problem however at most the bulb in the lcd maybe broken or shot. this does not happen often
so check the inverter first as this is the usual solution 98 percent of the time.
to replace it you remove the screws that are on the bezel that is the front of the display sometimes four max 6
gently lift the front bezel of the inverter is the electronical looking thing to the bottom of your screen
Posted on Jun 07, 2008
AOC 24" 2436V slight separation effect and capacitance buttons don't work
You may have a bad cable or the cable is running too close to a power supply or power cable. This can cause distortion and shadowing. Try moving or replacing the cables or the monitor to make sure it's away from any power sources.
Dec 05, 2013 | Computers & Internet
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Everything on the screen is blurry... not unreadable, but almost like there is a shadow behind everything.
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Feb 07, 2010 | HP Compaq FS7600 17" CRT Monitor
My samsung syncmaster 932b is blurry. There is a shadow slightly to the right of each object on the screen. How do I fix this?
cmwag, Try some isolation testing. Will 932b do same thing when connected to a different KNOWN GOOD pc? Will your pc display a sharp, bright, crisp, colorful screen when connected to a KNOWN GOOD monitor? Is the VIDEO card seated properly into its connector on the motherboard? Is VGA connector clean and tight into the port on back of pc? Hope this was of some use. 12fixlouie
Jan 29, 2010 | Samsung Computers & Internet
Letters blurr in spots and black boxes leave a shadow on the screen
Thank you.
Nov 23, 2009 | Acer P221W LCD Monitor
'Shadows' behind all texts and images on the screen
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
Shadowing of text
YOU ARE EXPERIENCING THE EFFECT OF GHOSTING.
iT CAN BE FIXED
cREATE A 1200X1600 100% WHITE .GIF TO USE AS A SCREEN SAVER. (IN WINDOWS YOU CAN ADD IT TO MY PICTURES SLIDESHOW)
Set this slide show to run after 2 minutes of non use.
Set the nonitor to power off in a short amount of non use.
say 15 minutes.
Do that for a couple of days and the ghosting affect will go away . You can then turn to a more reasonable screen saver.
I received this information from www.beginnercode.com
Feb 16, 2009 | HP L1706 17" LCD Monitor
Shadows
Thank you.
Feb 07, 2009 | Acer X193W LCD Monitor
Shadows and Ghosts on the Screen
Plugged up display via the VGA cable to an HP dv6000 laptop; the Acer powered up and displayed fine ... however, noticed a faint waving motion in the picture, as if the screen was literally gel and began to wave, from top to bottom as it appeared. Best I can describe it ... any suggestions as to why? I only connected it to this HP to try it out, I ordered it from newegg and wanted to make sure pixels werent dead on arival. I will be getting an Aurora 7500 (Alienware): AMD X2 6000, Windows Vista Premium, 2GB RAM, GeForce 512 8800GT, SLI ready motherboard ... I heard good things of Acer and hoped this display would look great with my soon-to-come setup and im sure it will. However, just nervous it will do this on my Aurora. Any help or suggestions would be beyond appreciated!!
Feb 19, 2008 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Problem with shadows showing on monitor
The solution to this is very simple. No software or hard ware changes required.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
