Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Re-Set the control panel
I just bought a Kenmore Dishwasher, I had some eletrical work done and now I can not get the start/resume light to stop flashing or the thing to start. Help!
tmanchav@aol.com
Thanks!!!
  • 1 more comment
  • Anonymous Jun 07, 2008
    clean
  • denisegayle Jun 07, 2008
    the clean light won't stop flashing
  • pskewen Nov 07, 2008
    I have the same problem. My dishwasher is 666.17019402.
    Problem Solver:
  • 19 Answers
If you are getting blinking lights on your console you may want to open up the door and visually look inside of the middle portion of your console and you'll observe an opening. this opening is where the latch and strike comes together to enaged power to the power board. you can take a butter knife and press the latch hooks downward. when you press the latch hooks(located on the latch then look at the front side of your console panel (at the same while holding the butter knife inside the latch keeping the latch hooks press down, press a wash cycle (normal, rinse, potspans, etc) and see if there is any more flashing. If not, then there is a bad connection with the latch.
Posted on Jun 10, 2008
Lock light on kenmore dishwasher is not disengaging stays on or sometime on/off and flickers,can't turn the machine on, it's a push button switch
Posted on Aug 10, 2008
    Problem Solver:
  • 6 Answers
Bad touch pad is correct!!
Posted on Jul 08, 2008
  • 868 Answers
Bad touch pad.
Posted on Jun 07, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
How do I fix a flashing Start/Resume light on a Kenmore Elite dishwasher model 665.13793K601?
These dishwashers are known to accumulate moisture in the keypad and then short. The solution that I have seen is to replace the keypad...It is possible that all of your issues with this dishwasher could point back to the keypad. After spending $$$ on the circuit boards, do you want to throw and additional $135 for a keypad? or replace the whole unit? Food for thought. Here is a link for you:
http://www.repairclinic.com/PartDetail/Control-Panel/8572855/1180767?modelNumber=665.13793K601?RCAID=1000065
May 22, 2014 | Kenmore Dishwashers
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Whirlpool dishwasher stops midcycle and control panel goes blank
and the controls dont advance? to the end of cycle?
Feb 26, 2009 | Dishwashers
Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
Nov 18, 2007 | Kenmore 16253 Stainless Steel Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
391 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
