Lg tromm front load washer machine
After we washing our clothes and dry them clothes we get a sour smell in towels.
BILL
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Try using www.affresh.com, in the wash using hot water. If your unit has a tub clean cycle use it. Leave the door open after using the unit to allow it to breath and wipe down the gasket. Use HE detergent and you don't have to use too much. That goes for the fabric softener as well.
Sgt 48
Posted on Jun 18, 2008
When i wash it smells like rooting eggs i tryed bleach and the tablets but smells up the hole house what wrong its a lg tromm wm-2487hwm steam washer
I had the same problem. You must take out your clothes immediately and leave the door open after every wash to let the inside of the washer completely dry. I believe I read to run a cycle of bleach water and wipe down the inside of the door and interior with bleach/water mixture. Then let it dry. You then can start washing your clothes again, but you must be diligent about leaving the door open to air out between washings.Hope this works for you. I almost sold my machines shortly after I bought them because my clothes were always smelly after washing. Leaving the door open has worked for us.
Dec 18, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Same problem with our LG Tromm
I had the same problem with my LG Tromm and was ready to throw away every one of my towels they were so rank smelling. As a last resort I filled the detergent area with one cup of white vinegar and ran a load through on hot. Then I washed them with just a tablespoon at most of detergent. They came out smelling fine, the mildew smell was completely gone. How long it will last, I don't know.
I also read somewhere recently that we all use way too much detergent in our washers and dishwashers. And surprise, surprise, the post went on to say that too much detergent in your towels/clothes can leave a musty, mildewy smell in them.
Now when I do laundry, no matter what it is, I use about 1/4 of the amount of detergent called for, even though the HE uses so much less. In all, maybe 1-2 Tbsp, and everything comes out just as clean.
Also, try using a product from Clorox just for front loading washing machines. It's Clorox Washing Machine cleaner...it seemed to help with the overall smell. And I agree, I will never buy this particular machine again.
Aug 10, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Clothes smell musty
Clean th filter in the front of tha machine. Than take an OLD towel and run a hot wash with chlorox.
After that you run it again with vinegar and that should relief your problem.
i have an LG too.
Jun 21, 2008 | LG WM-2077C Front Load Washer
Sour smell on towel after washing them
That is comon with LG.
Clean out the filter in the front.
Than take an OLD towel.
Wash with chlorox first a hot load. After that do the same but than with vinegar and that should take care of the SOUR problem
I have an LG too.
Jun 19, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
