Hitachi 50UX57B 50" Rear Projection Television Logo
Posted on Oct 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 50FX20B Hitachi where the color has split up and there's some form of ghosting. Could this be caused by a video card or video board if one are in there.
Anonymous
Level 3:
  • Hitachi Master 3,459 Answers
  • Posted on Oct 29, 2010
Anonymous
Hitachi Master
Level 3:
Answers
3459
Questions
5
Helped
849127
Points
5558
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
I have a 50FX20B Hitachi where the color has split - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Wattage
1 watt,Service Manual I have says RK42 3.3ohms RK46 1.8ohms RK50 2.7 RK54 1.5 RK58 3.9 RK62 2.2
The colors don't line up on my projection tv, what
U have convergence prob.it dead.Tries these websites.Tv Repair World.com,Ebay.com to buy a convergence kit,repair what in that kit.U know how to solder right?
1helpful
2answers
Hitachi 50FX20B convergence problem
RK42 is 2.7 ohm 1watt
RK46 &RK54 are both 2.2 ohm 1watt
RK50 & RK62 are both 3.3 ohm 1watt
RK58 is 3.9 ohm 1watt
They are all metal film (flameproof) 5% resistors
Hitachi 53SDX20B
Hi, common issue but difficult for lay person to fix, tube sockets and spark gaps on crt boards need to be cleaned, hard to get at but most local shops have probably done more than once, if you want to attempt get back to me & I`ll explain further, video-tek
Hitachi 50FX20B 50 inch: Blue Convergence --will not adjust
You need to change convergence amplifiers. Should be no problem for a professional
Hitachi, model 57UWX20B ghosting?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Powering on Hitachi TV
If all you hear is a click and you get no display on the screen, it sounds as though you need a repairman to come out and fix the circuit board. There are several things that cause this symptom on your set but the most common are convergenge amp failure, vertical, or power supply issues. Sometimes as simple as resoldering connections. Other times major troubleshooting and part replacement are required. The repair cost is usually between 175.00 and 375.00 hope you have a trustworthy and knowledgable repair person, good luck, Russmann.
2answers
Hitachi 50fx20b
convergance iC needs to be replaced.
http://serviceman.site88.net
2answers
Color ghosting
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
