I've connected my trendnet on a LAN via a switch. The LED light is on on the trendnet and it's...
(More)
I've connected my trendnet on a LAN via a switch. The LED light is on on the trendnet and it's actually flashing when the print command is issued but the printer does not print. I get a reply from the printer but it doesn't print from my remote applications which on wan this is where l cant print from but on my LAN l can print
I have the same problem. My laserjet 1018 appears offline in the trendnet TE100-P1U and...
(More)
I have the same problem. My laserjet 1018 appears offline in the trendnet TE100-P1U and "Printer Command Set" is on ACL. This print works with PCL 5.Is there a solution, please?
The utilities that came with the print server install OK, but get an error when attempting to...
(More)
The utilities that came with the print server install OK, but get an error when attempting to connect to the print server. Same issue - driver loads & finds print server (TE100-P1U) fine, sets IP address (& I can ping p/s ok) but Add Printer in Vista reports
"Windows cannot connect to the printer. Make sure that you have typed the name correctly, and that the printer is connected to the network."
then returns to the Add Printer window, listing U1 on PS-xxxxxx \\ps-xxxxxx\U1 as (only) network printer to select.
Running Vista Home Premium sp1.
The PC I'm doing the setup from is connected wireless to a Linksys wireless router; printer is hard-wired to 100Bt port on this router.
Ideas?
When I connect HP deskjet models 3520 or 3650 to the unit's USB port, power up the printer, and then...
(More)
When I connect HP deskjet models 3520 or 3650 to the unit's USB port, power up the printer, and then power up the device the USB light blinks very briefly then goes out and stays out. This happens consistently, even after the unit has been powered off for hours before trying again. Is it fried?
