Question about GE Spacemaker JVM1640SJ Microwave Oven
Burnt hole in microwave
When cooking several years ago whatever it was at the time caught on fire and was on the metal rack that comes with the microwave. Where the rack sits on the clips burned a hole in the side of the microwave and fryed the plastic clip. we by accident found we could continue to use the microwave by placing a piece of duct tape over the burnt hole. I am getting ready to sell the house and if at all possible would rather find a CORRECT way to repair the hole than have to buy a new one. Thank you, Hope Ellis
ladyhope2you@aol.com
  • 3 more comments
  • hopeellis Jun 08, 2008
    I have a GE SPACESAVER manufactured in 1994 that came with the house when we purchased it in 2003, The model is JVM240WL001. There is a hole the size of a quarter or smaller in the side of the microwave where the back right clip was. We have put a piece of duct tape over it and it has worked fine since the fire that burnt the hole in 2004. We are going to sell and would like to know if this problem is fixable or do we need to replace it before putting the house on the market. Thank you!> Hope Ellis
  • heidip2 Jun 19, 2008
    I have an ultrex microwave which has a flap on the side (not metal, some type of cardboard material covered with silver paint?). While microwaving, a spark (large) burned a hole into this flap. Where can I get a replacement? And what would cause it to spark like that?
  • caa1947 Jan 26, 2009
    We had a fire in our built-in microwave. It melted the plastic circle that helps turn the turntable and broke the turntable, both of which I have replaced. It also caused a warped adn burnt through place on the top inside of the microwave where the light is stored. Because of the warping, we now have a hole but the microwave works. It is safe to use? Can I seal it with duct tape?
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • Anonymous Mar 30, 2014
    Can you take the clips out and use the microwave without them?
  • GE Master
  • 9,098 Answers
Is the hole actually bigger than it originally was or is it just empty because the rack support got burned up & discarded?
The rack supports / rack holders can be ordered. The part number is WB06X10140 (or WB6X10140) and they're less than $5.00 each. You can find them in stock here.
If you install a new rack support in the hole, then any gap or hole around it can allow grease to accumulate, and that can lead to arcing. But you can seal it safely & easily.
Once the support is installed and everything is squeaky clean and dry, you can apply a small amount of silicone caulk into the gap or hole.
Let it dry it overnight with the door open, then use a razor blade or X-acto knife to gently trim away any excess caulk.
That would be a really good fix.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
Have Spacemaker Microwave--JVM1630WB 004. started cooking ,heard a POP!! , and it did not cook the food. smelled like burnt wires or capacitor. No fire. fuse did not blow. Any suggestions ?
I had the same thing happen to my 20 year old Frigidare microwave (it was 8 years old at the time). Same POP!, same failure. Though I'm handy with electrical, I don't mess around with the innards of a microwave. There are lethal doses of electricity stored in some capacitors even when the device is unplugged. I took mine to an appliance repair shop that works on microwaves. In my case, a high-end capacitor had blown. The repair cost me $80.00. $5.00 for the part, $75.00 for the labor. My microwave is still working 12 years later.
My solution is not pleasant. If you call a tech out to your house, his charge for labor and parts will probably be more than the cost of a new microwave. Taking it to a repair shop is cheaper, but you would want an estimate first which in itself will not be free of charge.
New microwaves have come down in price over the years. Countertop models for as little as $100.00. Over the range models starting at about $250.00.
Whatever you decide, this is going to cost you some money. Your microwave is dead. Good luck and hope I've helped a bit.
Jan 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Tip
DANGER WARNING! Potential Hazard if your microwave was working and now doesn't...
If you have this model microwave and it was working fine, then one day it stopped heating items placed inside there are a handful of different issues that could be the problem. In my case it was intermittent, over a period of a few days it would sometimes work (heat) and sometimes not. NO MATTER if this is what your's is doing or if it stopped heating all together. If you decide to let it dry out, or not use it for a while to see if it was a one time occurrence, or whatever the reason, the first time you put something in and probably for the next 10 times at least (this assumes it starts to work again), make sure you are right there with it while it is cooking. Don't assume you can put something in, go do something and come back when the timer is beeping. There is a chance (as this happened to me) that your food inside will CATCH FIRE! Normal food item placed inside, no metal, nothing different than the numerous times before when this had been cooked but when we smelled smoke we came running. Fortunately it started and finished inside the microwave but that's not a guarantee, it could spread. Play it safe. Never had a problem like this before and never heard of a microwave cooking something until it caught on fire (especially since the time entered for the cook was 30 seconds) but it did.
on Sep 23, 2013 | GE JVM1850SMSS Microwave Oven
I have a GE Profile convection/microwave oven, Model No JVM1790 BKC01. One of the plastic clips that holds the oven rack in place caught fire. Location of clip is top front right hand corner next to the...
Most rack support problems I have seen are from food splatter or grease getting around the support and even seeping behind it. Once it starts burining it must be replaced. It is really important to keep the area around them clean and dry and free from food splatter. A Microwave cannot tell what is on a plate or on the wall or rack support, and every food particle cooks each time the unit is run, until it turns to a carbon deposit and starts to attract the microwave energy and starts to ARC to that point.
Then it burns up the part it is arcing to. Have to replace support and scrub the area and inside of the cavity perfectly clean.
Oct 25, 2017 | GE JVM1790 Convection / Microwave Oven
Yam caught fire in microwave
If you have given the microwave enough time to cool off and it still does not work then I would suggest that you would need a new one, as the circuit board may be fried that connects the control panel.
Jan 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Caught fire
>Should a microwave be obsolete after 5 years?
Not at all. You can just order a new rack support (or a whole set of them).
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Quite often this arcing is due to grease or food particles stuck between the holder and the hole it goes into, etc.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Dec 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave exploded
it sounds like a common problem with burnt food stuck to the roof in side the oven basically the food just cooks and cooks and eventually burns through and can even set on fire, so i doubt its covered under warranty although you could just replace the roof give it a good clean and so long as the mags are ok you shouldn't have any problems... whats the make and model number it could be something more sinister but the above sounds like a best guess to me!!!!
Nov 12, 2008 | Maytag MMV5207A Microwave Oven
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
Nov 09, 2008 | GE JVM1190 Microwave Oven
ELECTRICAL POPING SOUNDS
Hi there - I assume you have a rack in the Microwave. What happens is the rack due to putting something in and out of the Microwave some times wears against the back wall of the cooking chamber. As this happens it wears through the paint and exposes the metal casework.
You then get microwave arcing between the metal rack in the microwave and the cooking compartment casing which gives that spitting popping sound. I would say get some white model paint and paint over the scorched spot (as long as its not gone so far as to wear a hole in the case work).
Wait for it to dry and stick the rack back in and try again to warm up a cup of coffee or something and see if it stops.
Also if you pull the grill slightly forward in the holders towards the door and test it you may notice that it doesn't pop as much so I would paint it and pull the grill forward and see if you still get the issue.
Best of luck.
Sep 04, 2008 | Whirlpool GH7155XHS Microwave Oven
Rack in microwave
You should not have any metals in the oven when the microwave is on. If you are just doing convection cooking, the metal rack should be in so that what you are cooking is raised up so the hot air can surround what you are cooking.
Apr 04, 2008 | Kenmore 63672 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
4,750 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
